Exam 300-101
anjelo421
hi guys,
yesterday 16/04/2016 i did my first attempt for 300-101 exam and i realized on CLi doesn't work question mark to seee what command next, i would like to know  does it normal behaviour as cisco programed for Routing exam  or if  i was given a broken keyboard on test center.
thanks in Advance
Philip D'Ath
I'm not familiar with that exam, but "question mark" usually works in the CLI simulators for IOS devices.
InayathUlla Sharieff
Agree with Philip that "?"  option on the simulator should have been worked.
As we have given the exams quite a long time not sure what has been changed now.
jonathanlunt
I remember from my CCNA that the help output was very limited. I guess this would be to test if the engineer has actually remembered the commands for whatever they are asking for.
Which makes sense, as the tests would be a lot easier if you could '?' through the whole thing. Once you have taken the test and find yourself in a network role, you can (like 99% of all engineers I have met) forget all the commands completely and use the '?' as much as you like!
