Is there any way to make standby Sup as active without reloading any Supervisor in cisco 4510R?
vinod rathore
I have cisco 4510R L3 switch with installed 2 Sup on slot 5 and 6. the current active Sup is in Slot5 i want to make active Sup6 in slot 6 which is currently standby sup in chassis.
Is there any way to make standby Sup to ACTIVE without reloading any of the Supervisor. however there is two way as per my understanding -
1. we can reload the active Sup so that standby Sup will take charge. - (redundancy reload shelf)
2. we can focefully switchover the state of Sup's by (redundancy forcefully swithover)
but in above both cases reload will be performed by one of the supervisor. which i don't want.
please see the attached output for more info
InayathUlla Sharieff
HI Vinod,
Unfortunately there is no way you can get the standby sup to take over the active role wihout have the active sup reload.
Inayath
HI Vinod,
Inayath
Thank You Inayath for comment !!!
