ISDN backup using dialers problem
up to now we were using ISDN lines to backup our componies branches and everything was working fine. Bellow I attach a sample config of the working situation:
Central site
(PRI)
controller E1 3/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial3/0:15
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
isdn switch-type primary-net5
(sample dialer int)
interface Dialer371
ip address 192.168.16.134 255.255.255.252
encapsulation ppp
ip ospf database-filter all out
dialer pool 1
dialer idle-timeout 0
dialer caller 2102855240
no cdp enable
Remote site (branch)
interface BRI0/1/0
bandwidth 64
ip address 192.168.16.133 255.255.255.252
encapsulation ppp
dialer map ip 192.168.16.134 broadcast 2106799800
dialer-group 2
isdn switch-type basic-net3
isdn point-to-point-setup
isdn calling-number 2102855240
no cdp enable
ppp multilink
access-list 101 deny   ospf any any
access-list 101 deny   udp any any eq snmp
access-list 101 deny   udp any any eq snmptrap
access-list 101 deny   udp any any eq ntp
access-list 101 deny   ip 192.168.91.0 0.0.0.255 10.130.128.0 0.0.0.255
access-list 101 deny   ip 192.168.91.0 0.0.0.255 10.150.128.0 0.0.0.255
access-list 101 permit ip 192.168.91.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 permit ip 192.168.91.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 101 permit ip 192.168.91.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 101 permit ip host 192.168.1.91 host 192.168.1.1
access-list 101 permit ip host 192.168.1.91 host 192.168.1.2
dialer-list 2 protocol ip list 101
What I want to try to accomplish is to use the ISDN line for both backup and out-of-band management (call the branch from the central site). It seems that I don't have a problem with the out-of -band management config (sample shown bellow - I can ping between the two endpoints)
(Central site config)
interface Dialer1371
ip address 10.123.123.1 255.255.255.252
encapsulation ppp
dialer pool 2
dialer string 2261089808
dialer-group 3
access-list 100 deny   ospf any any
access-list 100 deny   udp any any eq snmp
access-list 100 deny   udp any any eq snmptrap
access-list 100 deny   udp any any eq ntp
access-list 100 permit ip 10.123.123.0 0.0.0.255 10.123.123.0 0.0.0.255
dialer-list 3 protocol ip list 100
********* remote site config for out-of-band management **************
interface BRI0/1/0
bandwidth 64
no ip address
encapsulation ppp
ppp multilink
interface Dialer2
bandwidth 64
ip address 10.123.123.2 255.255.255.252
encapsulation ppp
dialer pool 2
dialer caller 2106799800
no cdp enable
The problem arises with the ISDN backup config. Bellow I have attached the corresponding config as well as the "debug ppp negotiation" output"
Central site  (same as original config)
(PRI)
controller E1 3/0
  framing NO-CRC4
  no ip address
  encapsulation ppp
interface Dialer371
encapsulation ppp
dialer pool 1
no cdp enable
Branch config
interface BRI0/1/0
bandwidth 64
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
encapsulation ppp
dialer pool 1
dialer string 2106799800
dialer-group 2
no cdp enable
Debug ppp negotiation (on branch side)
TELONIO-ATH-371#isdn test call int bri0/1/0 2106799800
TELONIO-ATH-371#
Feb 23 10:06:55 EET: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Feb 23 10:06:55 EET: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 2106799800 N/A
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Using dialer call direction
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Treating connection as a callout
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Session handle[A800000F] Session id[9]
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Phase is ESTABLISHING, Active Open
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: No remote authentication for call-out
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: O CONFREQ [Closed] id 17 len 32
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:    MagicNumber 0x92919AD8 (0x050692919AD8)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:    MRRU 1524 (0x110405F4)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:    EndpointDisc 1 TELONIO-ATH-371
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:     (0x13120154454C4F4E494F2D4154482D33)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:     (0x3731)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: I CONFREQ [REQsent] id 171 len 10
Feb 23 10:06:55 EET: BR0/1/0:1 LCP:    MagicNumber 0x5B9A7D2E (0x05065B9A7D2E)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: O CONFACK [REQsent] id 171 len 10
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: I CONFREJ [ACKsent] id 17 len 8
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: O CONFREQ [ACKsent] id 18 len 28
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: I CONFACK [ACKsent] id 18 len 28
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: State is Open
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Phase is FORWARDING, Attempting Forward
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Phase is ESTABLISHING, Finish LCP
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Phase is UP
Feb 23 10:06:55 EET: BR0/1/0:1 PPP: Process pending ncp packets
Feb 23 10:06:55 EET: BR0/1/0:1 IPCP: I CONFREQ [Not negotiated] id 1 len 10
Feb 23 10:06:55 EET: BR0/1/0:1 IPCP:    Address 192.168.16.134 (0x0306C0A81086)
Feb 23 10:06:55 EET: BR0/1/0:1 LCP: O PROTREJ [Open] id 19 len 16 protocol IPCP (0x80210101000A0306C0A81086)
Feb 23 10:06:56 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:1, changed state to up
IPCP never transitions to [OPEN] and the route to 192.168.16.133/32 is never inserted.
Any suggestions would be highly appreciated.
Thanks in advance,
Katerina
Ok, I got it working! It seems that the problem was something really minor For some reason somebody had removed the floating static "ip route 0.0.0.0 0.0.0.0 192.168.16.134 250" from the config!!!!
The working config for both isdn backup and out-of-band management is:
Remote branch
interface BRI0/1/0
bandwidth 64
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
description ISDN-backup
encapsulation ppp
dialer pool 1
dialer-group 2
no peer default ip address
fair-queue
no cdp enable
interface Dialer2
description OUT-OF-BAND MANAGEMENT
ip address 10.123.123.6 255.255.255.252
encapsulation ppp
dialer pool 2
no cdp enable
access-list 101 permit ip host 192.168.16.133 host 192.168.16.134   //this line is only for testing purposes
Main Site
interface Dialer371
description xxxxx
encapsulation ppp
dialer pool 1
fair-queue
no cdp enable
ip address 10.123.123.5 255.255.255.252
encapsulation ppp
dialer pool 2
dialer string 2102855240
dialer-group 3
Before I found the correct solution to the problem (missing route), I experimented with a lot of configurations and this was the most interesting (it helped me overcome the IPCP problem. In conjunction with the last entry in access-list 101 I finally managed to install the 192.168.16.134/32 route and that helped me see that the floating static was missing, because when i turned the traffic through ISDN I couldn't ping anything)!
Remote branch
interface BRI0/1/0
bandwidth 64
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 2
peer default ip address 192.168.16.134
fair-queue
no cdp enable
interface Dialer2
encapsulation ppp
dialer pool 2
no cdp enable
Main site:
interface Dialer371
description TELONIO ATHINON (LIMATA)
ip address negotiated
encapsulation ppp
dialer pool 1
fair-queue
no cdp enable
ppp ipcp mask request
description OUT-OF-BAND TELWNEIO-ATH
encapsulation ppp
dialer pool 2
dialer-group 3
Hope this helps anybody experiencing similar problems!
Katerina
