2975 limit port bandwidths
mcusine
I am trying to limit to 10 MB one gigabitethernet interface.
I am trying to apply the following :
policy-map bedsides
description Limite 10Mb Bedsides
class Bedsides
math ip
  police 10000000 8000 exceed-action drop
class class-default
interface xx
service-police input bedsides
I need to math multicast traffic only or all traffic, if I configure math any the switch give a message that it's not possible due a interface type.
I configured IP and a class-default.
What is the best way to limit the traffic in the switch model?. Any other option ?. Any command to check it's working fine?.
Thanks in advance and best regards,
Mauricio
6 Replies 6
Leo Laohoo
Try this basic command:
interface
speed 10
or
interface
speed auto 10
Thanks for your answer and I know these possibility. I am looking for other solution configuring police or something else.
Any other idea?.
Thanks and best regards,
Mauricio
Hi Mauricio,
You can allocate specific bandwidth to one interface. also to you can do the same to Vlan's.
See the below two individual steps may help in your scenario.
STEP-1:
Apply rate-limit on each interface in your 2975
Example (for 1024kbits):
Router# conf t
Router(config)# int gig 3/24
Router(config-if)#rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
Router(config-if)#rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
STEP-2:
Policy a specific VLAN number on VLAN interface.
class-map vlan5
match vlan 5
match class-map class-default
policy-map vlan5-limit
class vlan5
police 8000 1500 1500 conform-action transmit exceed-action drop violate-action drop
int vlan5
service-policy input vlan5-limit
After you apply this configuration, the traffic with VLAN 5 coming from any will be policed at 8Mbps. Like that you can allocate how much bandwith you want.
Hope this will help you.
Please rate the helpfull posts.
Naidu.
Hi Naidu,
Thanks for your email.
In the 2975 there is no exist rate-limit command :
% Unrecognized command
SW_P1R2(config-if)#rate-limit
and it's only a leyer 2 switch
Do you think that applying the service-policy to vlan will work? In the case of the answer be yes, it's a not very ussefll solution because I need to know how many interface will connect to the vlan, and I am not sure, and after I add one new interface to the vlan, it's necesary to madify the values.
Do you have any other idea that only apply to the interface?.
Mauricio
Hi Mauricio,
Please try below may help you...
class-map IP
match ip dscp default
policy-map 1meg
class IP
police 1000000 19200 exceed-action drop
int fa0/1
service-policy input 1meg
Naidu.
Hi Naidu,
Thanks again for your answer, I will try these configuration.
Do you think these conf will math multicast traffic and/or any traffic.
As a  posted in my frist message the Switch don't allow to configure math any.
Mauricio
