ISDN Dialer interface question
avionics
can anyone give me an example or tell me what i have wrong in my configurations. I can't make clients connected on one router connect or receive data from a connected router 2 the int dialer1 on which has the isdn connection for web access. here is my configs
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
interface BRI0/0/0
description connected to internet
bandwidth 64000
no ip address
encapsulation ppp
shutdown
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
interface BRI0/1/0
bandwidth 64000
no ip address
encapsulation ppp
shutdown
interface BRI0/2/0
bandwidth 64000
no ip address
encapsulation ppp
shutdown
interface BRI0/3/0
bandwidth 64000
no ip address
encapsulation ppp
shutdown
interface FastEthernet1/0
shutdown
interface FastEthernet1/1
shutdown
interface FastEthernet1/2
shutdown
interface FastEthernet1/3
shutdown
interface FastEthernet1/4
shutdown
interface FastEthernet1/5
shutdown
interface FastEthernet1/6
shutdown
interface FastEthernet1/7
shutdown
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
no ip address
interface Dialer1
bandwidth 256000
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer idle-timeout 180
dialer string "28"
dialer hold-queue 10
dialer load-threshold 10 outbound
dialer max-call 4
dialer-group 1
no cdp enable
ppp pap sent-username xxxxxxx password 0 xxxxxxx
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
end
router 2
bridge irb
description unsecured test configuration
no ip address
ip nat inside
no ip route-cache
duplex auto
speed auto
bridge-group 50
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 50
description "DV2"
description "STAFF4"
description "STAFF2"
description "DV1"
description "STAFF3"
description "STAFF1"
description "CSOSTATION"
description "ACCELERATOR"
description "WHISPER900PROVISION"
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
ip nat inside
no ip route-cache
bridge-group 50
interface BVI50
ip address 192.168.1.2 255.255.255.0
ip classless
Richard Burts
Thomas
You posted the configuration of the first router as part of a thread that you started on Feb 3. In that discussion there were suggestions made about things that needed to be added to the address translation to make it work. And I made the observation that with all of the BRI interfaces in shutdown that it is impossible for the dialer interface to work. It seems that neither of these issues has been addressed. I suggest that you rectify these issues and then tell us what is working and what is not working.
Rick
Rick
this config does not show the changes but the nat and interface have been turned on. to clarify things a little more. i can make a connection (dialer call out) when i ping using the IOS. but the clients are not activating the dialer interface. I can telnet into the router with the dialer from a client but the clients are not able to access the web.
Thomas
If you have made config changes it would be very helpful to post the current version of the config.
And your description:
has me a bit confused. I think I understand that the router (IOS) is able to activate when calling out. But I am a bit confused about what happens (what works and what does not work) if the client initiates the connection. Perhaps you could clarify this?
Rick
Rick
