Isolated Vlan Can Ping Primary VLAN on VTP Primary but not VTP Client
hfakoor222
I have a host PC, DLS2-PC top right side of topology below. It belongs to secondary isolated VLAN 151, for the main vlan 150.
Switch DLS1 in the VTP primary whereas switch DLS2 is VTP server version 3. From host PC DLS2-PC2 can ping interface vlan 150  172.16.150.1 on DLS1 but not interface vlan 150 172.16.150.2 on DLS2. From this host PC I can also ping VLAN 1 on most of my switches given how my protocol is set up (I still cannot ping VLAN 1 on DLS2, I'm trying to work this out, but not a concern - I can ping VLAn 1 on DLS1). My concern is why can I ping VLAN 150 on VTP primary DLS1 switch (151, 152 are private VLANs which 150 is the main vlan) and not ping VLAN 150 on DLS2 switch?
I changed gateway on my host pc to 172.16.150.2 (int VLAN 150 on DLS2), and can still only ping VTP primary switch and not DLS2 switch  see below where I change gateway to 172.16.150.2, and it timesout
Isolated hosts can not communicate with other hosts. However they can communicate with the main vlan the isolated vlan belongs to according to documentation.  According to pings it can also ping VLAN 1 on different switches (below DLS2-PC2 is pinging Vlan 1 on ALS1 and DLS1).  Note 172.16.2.3 is on ALS1
No on ALS1 I make it into a vtp vclient and add a VLAn 150 interface after updating DLS1 to propegate ALS1 vlan database
Here's ALS2 commands for VTP
And now DLS2-PC2 can ping vlan 1 on ALS1 but not VLAN 150, even though according to documentation vlan 150 is responsible for communication between private vlans and rest of network
"The PVLAN traffic flows are unidirectional from the host ports to the promiscuous ports. Traffic received
on primary VLAN enforces no separation and forwarding is done as in a normal VLAN.......
To allow host ports in secondary VLANs to communicate outside the private VLAN, you associate secondary
VLANs to the primary VLAN. If the association is not operational, the host ports (community and isolated
ports) in the secondary VLAN are brought down."
page 4
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/layer2/503_U2_1/b_Cisco_n3k_layer2_config_guide_503_U2_1/b_Cisco_n3k_layer2_config_gd_503_U2_1_chapter_0101.pdf
So according to what I have above I'm assuming that because it is not VTP primary the VLAN 150 on other switches cannot manage isolated vlan 151. I set DLS2 switch to a different VTp domain and still could not communicate with VLAN 150 on DLS2. So far it seems the isolated secondary VLAN can only communicate with VTP primary main VLAN 150, and not with vlan 150 on the other switches, and it seems like it was done like this by design.
Or am I missing something?
Any thoughts?
Below is topology and configs.
DLS2   SWITCH
May 12 20:43:24.570: %SYS-5-CONFIG_I: Configured from console by consolerunning-config
Building configuration...
Current configuration : 3862 bytes
! Last configuration change at 20:43:24 UTC Thu May 12 2022
version 15.2
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface GigabitEthernet0/0
switchport private-vlan host-association 150 151
switchport mode private-vlan host
media-type rj45
negotiation auto
interface GigabitEthernet0/1
switchport private-vlan host-association 150 152
media-type rj45
negotiation auto
interface GigabitEthernet0/2
media-type rj45
negotiation auto
channel-group 1 mode on
interface GigabitEthernet0/3
media-type rj45
negotiation auto
interface GigabitEthernet1/0
media-type rj45
negotiation auto
channel-group 2 mode on
interface GigabitEthernet1/1
media-type rj45
negotiation auto
interface GigabitEthernet1/2
media-type rj45
negotiation auto
interface Vlan1
ip address 172.16.2.2 255.255.255.0
interface Vlan150
ip address 172.16.150.2 255.255.255.0
private-vlan mapping 152
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 172.16.2.1 255.255.255.255 172.16.2.1
control-plane
DLS1 Switch
urrent configuration : 4026 bytes
! Last configuration change at 20:45:12 UTC Thu May 12 2022
version 15.2
hostname DLS1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree vlan 150-152 priority 24576
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
switchport access vlan 152
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
interface Vlan1
ip address 172.16.2.1 255.255.255.0
interface Vlan77
no ip address
shutdown
interface Vlan150
ip address 172.16.150.1 255.255.255.0
private-vlan mapping 151-152
no ip http server
ip route 172.16.2.3 255.255.255.255 172.16.2.3
control-plane
banner exec ^C
hfakoor222
Please note according to the lab I am taking this from DLS1-PC1 (top left of topology) can in dact ping vlan 150 on other switches, ehich is the case in my topology
DLS2-PC2 should not be able to ping vlan 150 on DLS2 according to the lab, which is my situation as well.
VTP version 3 propegation should work with Private VLANS according to the lab which is what i did. I defined the VLANS on DLS1 and not on otther switches. They were however propegated as private VLANS
below is DLS2
 Not sure which switch is this, the IOS I saw that is 15. But, where did you define that vlan 150 is the primary?
The syntax change a lot among devices but I expected to see something like:
switch(config)# vlan 150
switc(config-vlan)# private-vlan primary
switc(config-vlan)# end
