ISR 2921 sub-interface
Imran Ahmad
Level 6
Level 6
I want to connect 2 ISP links into one  Gigabit-interface on my Router 2921, can any one tell me how to do that ?    sub-interface creation is not possible on cisco 2921
plz help me
2 Accepted Solutions
Hi Imran,
I didn't realize that the switch doesn't even have a login option 😞 So it would be more of like a HUB then. It worth checking (google it) if your switch model understand 802.1q tagged frames.More likely they wouldn't be. In that case you will have go with a manageable switch. Also it worth trying to have your router configured with sub interface and connecting the port to your unmanageable switch and see if you are able to ping your service providers router.
As updated before another option you could try is secondary ip address but again that is not a scalable option and i wouldn't recommend the same for a long run.
Najaf
No i can not connect 2-isps into 2 gi0/1 and gi0/0,  because that is used for other purposes.  we have only one Gigiabit-int availble that has to be connected into 2-isps .
Then you have to use a different switch or a module in the router. I would go for the module as there will be one device less to manage.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
11 Replies 11
kcnajaf
Level 11
Level 11
Hi Imran,
Are you sure that sub-interface creation is not possible in 2921?
Also if you have 2 ISP links I would assume there would be two physical cables coming from these ISP's as well. Is that not the case????
Not sure if secondary ip address on the interface will do the job for you as below even though it is not a good practice.
interface FastEthernet0/0
ip address 192.168.10.10 255.255.255.0 secondary
ip address 10.10.10.10 255.255.255.0
shutdown
Najaf
CCIE (R&S) 25070
Subinterfaces can also be configured on a 2921. Here is an example:
interface GigabitEthernet0/1
  no ip address
  duplex auto
  speed auto
interface GigabitEthernet0/1.16
  encapsulation dot1Q 116
  ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/1.10
  encapsulation dot1Q 10
  ip address 10.10.10.1 255.255.255.0
Thanks Karsten,  yes after your example, it is possible to configure sub-interfaces on 2921. because i didnt know that
can you tell me after adding those 2-sub-interfaces into  2-vlans (116 & 10) ,   then the Router interface GigabitEthernet0/1  should be physically connected into a switch which must be a managable switch ? and should configure that switch port as TRUNK LINK for vlans (116&10) ?
im asking the question, because i dont have cisco switch in between my 2-ISPs and my Router,    that is a normal D-Link switch  (Un-Managable Switch)
Please tell me what is the solution ?   my d-link switch is not configurable, it is plug&play
Hi Imran,
You dont need a managable switch. You can use a un managable switch and put two ISP's in different VLAN (116 & 10) and configure the switch port as trunk which is getting connected to yout 2921 router.
Hopet his helps
Najaf
CCIE (R&S) 25070
Hi Najaf,
But how to configure un-managable switch-port as Trunk ?
Yes, you need a managed switch in that case. The Port to the router has to be a trunk port and the two ports to the ISP-routers have to be in their VLANs as an access-port. A cheap SG300-8 would do that job.
Two other ways to solve that:
1) Use gig 0/0 and gig 0/1 for your ISPs and gig 0/2 for your internal connection. There you probably have a managed switch if you need more logical interfaces.
2) Use a switch module that you install in one of the slots and configure vlans for the ISPs there:
http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html#esm
Najaf ,  you suggested me to configure the Un-Manageble switch-port as Trunk.  but how to do that,  un-managable switch means that isnot configurable .  i can not login or enter to that d-link siwtch
Hi Imran,
Najaf
Hi Imran,
Najaf is correct please consider him, in this scenario you should need layer 3 switch or Manageble swtich to got the subinterfaces with trunking between the different Local VLANS.
Thanks to  Imran
Naresh
Thank you all for your support. i will go for manageable switch ,  i think i will go with Kareten suggeted cheap switch  SG300-8
