InterVLAN can not ping problem with Dynamipsgui
mar.stanley
Community Member
Switch1 in vlan2 ping 10.10.2.1 vlan 1 of Switch2 no response
Switch using 3640 image
Router using 7200 image
f1/0 10.10.1.2 - f0/0 Switch1 172.16.0.3 f0/2 - P0/0
                                f0/1
Router                         |
                                f0/1
f1/1 172.16.0.2 - f0/0 Switch2 10.10.2.1 f0/2 - P0/1
Router1
config t
int f1/1
speed 100
duplex full
ip address 172.16.0.2 255.255.0.0
no shutdown
int f1/0
speed 100
duplex full
ip address 10.10.1.2 255.0.0.0
no shutdown
end
Switch1
config t
int f0/0
speed 100
duplex full
end
//vtp domain SampleDomain
vlan database
vlan 2
config t
int vlan 2
ip address 172.16.0.3 255.255.0.0
no shutdown
exit
ip default-gateway 172.16.0.2
end
Switch2
config t
int f0/0
speed 100
duplex full
end
config t
int range f0/0
switchport mode access
switchport access vlan 1
int vlan 1
ip address 10.10.2.1 255.0.0.0
no shutdown
exit
ip default-gateway 10.10.1.2
end
config t
int range f0/2
int vlan 1
no shutdown
exit
end
Hi Stanely,
Get idea from Here:
Create sub-interfaces, set 802.1Q trunking protocol and ip address on each sub-interface
Router(config)#interface f0/0
Router(config-if)#no shutdown
(Note: The main interface f0/0 doesn’t need an IP address but it must be turned on)
Router(config)#interface f0/0.0
Router(config-subif)#encapsulation dot1q 15
Router(config-subif)#ip address 192.168.15.1 255.255.255.0
Router(config-subif)#interface f0/0.1
Router(config-subif)#encapsulation dot11 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
(Note: In the “encapsulation dot1q 15″ command, 15 is the VLAN ID this interface operates in)
Configure VLAN
Switch(config)#vlan 15
Switch(config-vlan)#name SALES
Switch(config-vlan)#vlan 20
Switch(config-vlan)#name TECH
Set ports to access mode & assign ports to VLAN
Switch(config)#interface range fa0/1
Switch(config-if)#no shutdown
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 15
Switch(config-if)#interface range fa0/3
Switch(config-if)#switchport mode access
Switch(config-if)# switchport access vlan 20
see the example:If you are configuring on layer 3 switch:
ip routing
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/3
interface Vlan15
interface Vlan20
And on hosts just assign IP addresses and default gateways (to the corresponding interface VLANs) -> hosts in different VLANs can communicate.
Please rate if it helps
5 Replies 5
cadet alain
post a diagram please because it's not easy to see what you did.
Regards.
Alain
host1b should be able to ping host2b, however, i do not know how to simulate pc in dynamipsgui though i configured XPC
so, i try to ping host2a from host1b
later, i try to perform inter-vlan routing by MultiLayer Switch
close all things and start again, then, shutdown ports in router
switch 2 can not ping switch 1's default gateway of VLAN 2
i am not sure 3640 whether it is multi layer switch, can dynamipsgui simulate intervlan routing by multilayer switch?
Hi Stanely,
Get idea from Here:
Configure VLAN
ip routing
interface Vlan15
interface Vlan20
in GNS3 you can do intervlan routing with SVIs using the "L3 switch" which is a router platform with a 16 port ethernet switch module( NM16-ESW).
to simulate hosts: take a router and disable ip routing and configure a default-gateway:
conf t
no ip routing
ip default-gateway x.x.x.x
Regards.
Alain
success now, exact follow the tutorial in my hand get error because no real pc exist
in switch 2, config have to change and separate to write, it is easy to be wrong when use range
and the diagram remind me, i found that i miss the link between switch 1 and switch 2, in experiment of tutorial center may have already set up this
link or my tutorial missing this part, sorry, it's my first time to use dynamipsgui and my first time
to set up cisco devices, luckily fix this in one week
