ISR C891F Trouble setting up zone based firewall
nbaker011
Hello, I'm trying to convert over from using ACL/CBAC rules to Zone Based. I've looked a several examples and to just get the basics going seems simple enough, but I can't quite get things to work. I suspect there is some hangover from the CBAC configuration that is interfering?
The network is simple.
AT&T DSL Modem/Gateway: Static IPs assigned 10.10.10.248-10.10.10.254 (Gateway is at 10.10.10.254, Firewall disabled)
C891F:
- Gi8 connected to Modem with Static WAN mapping 10.10.10.251
- Gi0-7 connected to LAN
- 1 VLAN for LAN 192.168.100.0, Router at 192.168.100.1
The devices on the LAN can communicate with each other. nslookup accesses the Gateway 10.10.10.254 which I can ping as well. However, I can't reach anything beyond the Gateway. E.g. ping to www.google.com resolves the DNS ok, but ping fails. The result is the same when ssh into the Router.
Below is full config. Please let me know if there is anything obvious.
Nick.
Building configuration...
Current configuration : 7669 bytes
! Last configuration change at 18:54:59 UTC Wed Feb 8 2017
version 15.3
service config
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname C891F-2
boot-start-marker
boot-end-marker
aqm-register-fnf
security authentication failure rate 10 log
security passwords min-length 6
logging console critical
enable secret 5 <snip>
enable password 7 <snip>
aaa new-model
aaa authentication login local_auth local
aaa session-id common
crypto pki trustpoint TP-self-signed-1341393301
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1341393301
 revocation-check none
 rsakeypair TP-self-signed-1341393301
crypto pki certificate chain TP-self-signed-1341393301
 certificate self-signed 01
<snip>
   quit
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.100.1 192.168.100.99
ip dhcp pool vlan 100
 import all
 network 192.168.100.0 255.255.255.0
 domain-name mydomain.org
 dns-server 10.10.10.254
 default-router 192.168.100.1
ip dhcp pool nuc2pool_vlan100
 host 192.168.100.80 255.255.255.0
 client-identifier 01b8.aeed.73d2.ed
no ip bootp server
ip domain name mydomain.org
ip name-server 10.10.10.254
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip cef
login block-for 5 attempts 3 within 5
no ipv6 cef
license udi pid C891F-K9 sn FGL203823UC
username admin password 7 <snip>
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh pubkey-chain
  username admin
class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
 match access-group name INSIDE-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-INSIDE-CLASS
 match access-group name OUTSIDE-TO-INSIDE
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
 class type inspect INSIDE-TO-OUTSIDE-CLASS
  inspect
 class class-default
  drop log
policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
 class type inspect OUTSIDE-TO-INSIDE-CLASS
  inspect
 class class-default
  drop log
zone security INSIDE
zone security OUTSIDE
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
 service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
 service-policy type inspect OUTSIDE-TO-INSIDE-POLICY
interface BRI0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 encapsulation hdlc
 shutdown
 isdn termination multidrop
 isdn point-to-point-setup
interface FastEthernet0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 description PrimaryWANDesc_
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 ip verify unicast source reachable-via rx allow-default 100
 zone-member security OUTSIDE
 duplex auto
 speed auto
 no cdp enable
interface Vlan1
 ip address 192.168.100.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 zone-member security INSIDE
interface Async3
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 encapsulation slip
ip forward-protocol nd
no ip http server
ip http access-class 20
ip http secure-server
ip http secure-port 8444
ip dns server
ip nat inside source static tcp 192.168.100.80 80 interface GigabitEthernet8 80
ip nat inside source static tcp 192.168.100.80 3389 interface GigabitEthernet8 3389
ip nat inside source static tcp 192.168.100.80 21 interface GigabitEthernet8 21
ip nat inside source route-map OUTSIDE-POOL interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip route 192.168.100.0 255.255.255.0 GigabitEthernet8 dhcp
ip access-list extended INSIDE-TO-OUTSIDE
 permit ip 192.168.100.0 0.0.0.255 any
ip access-list extended NAT-TO-OUTSIDE
ip access-list extended OUTSIDE-TO-INSIDE
 permit tcp any any eq echo
 permit tcp any any eq www
 permit tcp 10.10.10.248 0.0.0.7 any eq 3389
 permit udp any any eq domain
 permit udp any eq domain any
 permit icmp any any echo-reply
 permit icmp any any time-exceeded
 permit icmp any any packet-too-big
 permit icmp any any traceroute
 permit icmp any any unreachable
logging trap debugging
logging facility local2
dialer-list 1 protocol ip permit
no cdp run
route-map OUTSIDE-POOL permit 10
 match ip address NAT-TO-OUTSIDE
 match interface GigabitEthernet8
snmp-server community public RO
access-list 2 permit 192.168.100.0 0.0.0.255
access-list 20 permit 192.168.100.0 0.0.0.255
access-list 20 remark HTTP Interface
access-list 100 permit udp any any eq bootpc
access-list 100 remark UNICAST SOURCE VERIFY
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 login authentication local_auth
 no modem enable
 transport output telnet
line aux 0
 exec-timeout 15 0
line 3
 exec-timeout 15 0
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 password 7 <snip>
 transport input telnet ssh
scheduler allocate 20000 1000
end
Philip D'Ath
This isn't really right.  Please remove:
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
no ip route 192.168.100.0 255.255.255.0 GigabitEthernet8 dhcp
And add:
ip route 0.0.0.0 0.0.0.0 dhcp
Also check out my config wizard for the 897 which will generate a lot of the config for you.
http://www.ifm.net.nz/cookbooks/890-isr-wizard.html
Philip D'Ath
And add:
Thanks, yes, removing those lines worked. Maybe unrelated, but it then locked me out of ssh when I did this, so I need to find the serial cable again before trying the rest.
Nick.
