ISR dual WAN failover/load balancing with CCP?
ingramcanada
reading off this forums it seems there are many approaches to setting up dual WAN's on a ISR.
This is a very common scenario and would be nice to obtain a clear answer.
Clearly, this cannot be done with static routes I believe.
I read about IP SLA,(same as Object tracking ?) and also NAT loadbalancing.
Which is the best? Do they all work for loadbalancing or only failover?
Finally, can this be done through CCP?
ingramcanada
BUMP
So from further investiagtion, I believe that Policy Based Routing using NAT Load Balancing is the best way for this.
Can this be configured through CCP ?
