Issue connecting Catalyst 4948-10GE to ISP
TonnyRomm
   I have the following network :
My ISP provided my with the following data :
IP : 205.164.28.14
Netmask : 255.255.255.128
Gateway : 205.164.28.1
I configured Gi 1/20 as an L3 port with params provided by ISP
Port Gi 1/22 is part of VLAN4
The problem is : my "localpc" is not seeing the internet. I can't ping the gateway provided by my ISP (205.164.28.1)
I can ping from localpc to vlan4 (192.168.1.230). Also I can ping from localpc to L3 port (Gi 1/20) (205.164.28.14).
I use : cat4500-entservicesk9-mz.122-53.SG.bin image
What am I doing wrong ?
By the way, if I connect localpc to a linux router and configure the router with data provided by ISP it will have access to the internet.
TonnyRomm
By the way, from switch I can ping everything, including 205.164.28.1 and other hosts from internet
mainswitch#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/52/68 ms
You would have to perform NAT on the Catalyst, but I'm not sure the 4948-10GE knows how to do that...
4948-10GE does not supports NAT, I don't need NAT in order to connect to the Internet.
You're right about the first part - the 4948 doesn't seem to support NAT.  As for the second part... well, good luck browsing the Internet with an 192.168.x.x source IP address.
