Issue:" Problems with OTV"
Liad Dayan
Hi guys.
Iam having some trouble adding OTV in our network.
I`ve got 2 sites. in one site i got 1 N7K and on the other site i got 2 N7K.
all of them must have full reachability.
Now i start to configure it over an OSPF process:
I created 2 VDC on each Nexus
1 VDC for L3
1 VDC for OTV configuration.
this is my configuration:
Site with 1 N7K:
VDC-OTV:
interface ethernet 5/2
no switchport
ip router ospf 1 area 0.0.0.0
ip pim sparse-mode
ip igmp version 3
interface overlay 1
otv joined-interface ethernet 5/2
otv extanded-vlan 2-99
otv control-group 239.1.1.1
otv data-group 232.1.1.0/28
VDC-L3
interface ethernet 1/1 (To Joined Interface OTV)
ip address 192.168.1.2 255.255.255.0
ip pim sparse-mode
ip igmp version 3
interface ethernet 1/2 (To 1 N7K on other site)
ip address 172.16.1.1 255.255.255.0
ip pim sparse-mode
interface ethernet 1/3 (To 2 N7K on other site)
ip address 172.16.2.1 255.255.255.0
ip pim sparse-mode
ip pim rp-address 192.168.1.1 (ME)
The other 2 VDC has the same configurations.
I have a full connectivity in OSPF, But i cant see any OTV mac learning .
Anyone have any idea how to fix it?
Jerry Ye
I see three problems:
1) You shoud not configure ip pim sparse-mode on the OTV joint interface in the OTV VDC. This is not required. The joint interface is a multicast client, not part of the multicast path.
2) Your RP has the same IP as the OTV joint interface (192.168.1.1)???
3) I don't see the full OTV configuration. Where is the OTV site-vlan and site-id???
Please correct the above and then post the following:
show otv
show otv adj
show otv isis adj
jerry
