Issue regarding nexus topology
Liad Dayan
Hi guys,
Iam having some trouble managing the nexus topology.
i have 2 nexus 7010
i have 2 nexus 5k
and i have 6 nexus 2k connected to the 5k as a fex fabric.
Now ,
The 5k connected and they are doing vpc connectivity between them (vpc keep-alive,and such).
We want to connect the nexus 7k to the nexus 5k with vpc.
The nexus 7k got vpc between them (vpc keep-alive , and such)
everytime i set up the vpc vs the port-channel the ports shut down and cause the nexus`s to lose connectivity.
here is the configuration regarding this senario:
N7K-1
interface ethernet 1/1
channel-group 50 mode on
interface port-channel50
switchport
switchport mode trunk
vpc 50
N7K-2
switchport
vpc 50
*** for couple of seconds it stays up and running and suddenly it shuts.
allso i tryed to configure it with spanning-tree port type network but it didnt help.
Somone have idea?
vann_will
is it possible for you to post the sh vpc brief, sh vpc role, and sh vpc peer-keepalive
vann_will
Do you have any Active vlan's going across the VPC Ports from the 5K's to the 7K's?
yea i do have active vlan accross the VPC ports.
here is the show commands you asked for;
OTV_L2_VERED-1-VERED-DC-1# show vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 2
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 3
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1,4-7,11,208,300,997,999,2052-2054,2134
vPC status
id   Port   Status Consistency Reason                     Active vlans
11   Po11   up     success     success                    1,4-7,11,20
                                                          8,300,997,9
                                                          99,2052-205
                                                          4,2134
12   Po12   up     success     success                    1,4-7,11,20
                                                          8,300,997,9
                                                          99,2052-205
                                                          4,2134
50   Po50   down*  success     success                    -
OTV_L2_VERED-1-VERED-DC-1# show vpc peer-keepalive
--Peer is alive for             : (5476) seconds, (283) msec
--Send status                   : Success
--Last send at                  : 2012.09.03 02:48:33 583 ms
--Sent on interface             : Eth3/4
--Receive status                : Success
--Last receive at               : 2012.09.03 02:48:33 693 ms
--Received on interface         : Eth3/4
--Last update from peer         : (0) seconds, (526) msec
vPC Keep-alive parameters
--Destination                   : 10.0.10.2
--Keepalive interval            : 1000 msec
--Keepalive timeout             : 5 seconds
--Keepalive hold timeout        : 3 seconds
--Keepalive vrf                 : default
--Keepalive udp port            : 3200
--Keepalive tos                 : 192
2nd
vPC domain id                     : 2
vPC role                          : secondary
vPC status
                                                          8,300,997,9
                                                          99,2052-205
                                                          4,2134
                                                          8,300,997,9
                                                          99,2052-205
                                                          4,2134
OTV_L2_VERED-1-VERED-DC-2# show vpc pee
--Peer is alive for             : (5544) seconds, (301) msec
--Last send at                  : 2012.09.03 02:49:42 576 ms
--Sent on interface             : Eth3/8
--Last receive at               : 2012.09.03 02:49:42 342 ms
--Received on interface         : Eth3/8
--Last update from peer         : (0) seconds, (786) msec
--Destination                   : 10.0.10.1
On the Nexus 5000
I have just a port-channel configured as;
  speed 10000
  storm-control broadcast level 0.50
  storm-control multicast level 0.50
