Issue: Switch Cissco 4500 automatic reboot
hannv3001
Hi Cisco Team.
I have issue with Catalyst 4500 device, it is automatin reboot while use.
I sent to team some information this device
Version: Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.03.00.SG RELEASE SOFTWARE (fc3)
System returned to ROM by reload
Last reload reason: Unknown reason
Is this a bug in the device???
Please, help me to check and response
Thank Cisco Team
Mohsin Alam
The IOS that you are running is very old. you might be hitting a bug.
Consider upgrading to latest stable release.
You can also check the power supplies if they are working good.
## Make sure to mark post as helpful, If it resolved your issue. ##
