Issue: the switch is rebooting continuously
frbachel05
Hi everybody,
I have a trouble with a switch (switch 1 master of  3 switchs in one stack)  that is rebooting continuously when i connect a machine on it.
Historic:
I rebooted the stack because of electric cut.
After startup completed, the switch 1 master rebooted again and again
I turned off the switch 1 and I downgraded the priority level
I powered on the swtich and it has been added to the stack with slave position.
If i don't connect PC on it, it's ok but as soon as i connect a PC, the switch is rebooting
When i connect or remove a PC on the switch, it reboot with logs below:
*Mar  1 00:00:34.342: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:00:46.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:48.309: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:00:51: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:51 UTC Mon Mar 1 1993 to 01:00:51 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:00:51: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:00:51 MET Mon Mar 1 1993 to 01:00:51 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:01:22: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:01:23: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:01:23: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:01:23: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:01:24: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal
*Mar  1 00:01:24: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:01:24: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:01:25: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.248.7 Port 514 started - CLI initiated
*Mar  1 00:01:28: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.160.50 Port 514 started - CLI initiated
*Mar  1 00:01:53: %PARSER-6-VIEW_SWITCH: successfully set to view 'root'.
FRNTE-E2-12-CS3750-01#
*Mar  1 00:02:26: %AUTHMGR-5-START: Starting 'mab' for client (f0de.f158.3b0c) on Interface Fa1/0/33 AuditSessionID 0A44E11E0000000000023D25
*Mar  1 00:02:28: %LINK-3-UPDOWN: Interface FastEthernet1/0/33, changed state to up
*Mar  1 00:02:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/33, changed state to up
01:02:40 MET Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 1F03708
-Traceback= 1F03708
=== Flushing messages (01:02:40 MET Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar  1 00:02:43: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:02:40: %Insufficient flash filespace for extended crashinfo.
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x018BA7A0  SRR1 = 0x00029230  SRR2 = 0x017613DC  SRR3 = 0x00021000
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x8C000000  DBSR = 0x00800000
CPU Register Context:
Vector = 0x00002000  PC = 0x01F03708  MSR = 0x00029230  CR = 0x30000095
LR = 0x0191B180  CTR = 0x0178AD2C  XER = 0xA0000079
R0 = 0x00000001  R1 = 0xFFFFFFAC  R2 = 0x00000000  R3 = 0x02B6AAB0
R4 = 0x0514C3C8  R5 = 0x00000000  R6 = 0x00000001  R7 = 0x00000014
R8 = 0x778D4B3D  R9 = 0x03860C28  R10 = 0x003C0001  R11 = 0x00000000
R12 = 0x30000093  R13 = 0x00110000  R14 = 0x03340000  R15 = 0x04D69DF0
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x04D69E48  R19 = 0x00000001
R20 = 0x0514C3C8  R21 = 0x0000003C  R22 = 0x0514C3C8  R23 = 0x00000025
R24 = 0x0514C3C8  R25 = 0x00000025  R26 = 0x003C0001  R27 = 0x73850001
R28 = 0x00000025  R29 = 0x003C0001  R30 = 0x03340000  R31 = 0x02B6AAB0
Stack trace:
PC = 0x01F03708, SP = 0xFFFFFFAC
Frame 00: SP = 0x00000000    PC = 0x00000000
FRNTE-E2-12-CS3750-01 uptime is 2 minutes, 44 seconds
cisco WS-C3750-48P (PowerPC405) processor (revision E0) with 131072K bytes of memory.
Processor board ID CAT0909R05P
Initializing flashfs...
flashfs[1]: 625 files, 10 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 15872000
flashfs[1]: Bytes available: 126976
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
% There may not be enough space available to collect the complete crashinfo
% It would be advisable to have 282836 bytes free space on flash:crashinfo
Press RETURN to get started!
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
*Mar  1 00:00:38.403: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:00:51.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:52.370: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:00:55: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:55 UTC Mon Mar 1 1993 to 01:00:55 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:00:55: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:00:55 MET Mon Mar 1 1993 to 01:00:55 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:01:26: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:01:27: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:01:27: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:01:27: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:01:28: %SYS-5-RESTART: System restarted --
*Mar  1 00:01:28: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:01:28: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:01:29: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.248.7 Port 514 started - CLI initiated
*Mar  1 00:01:32: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.160.50 Port 514 started - CLI initiated
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: System previously crashed with the following message:
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Copyright (c) 1986-2009 by Cisco Systems, Inc.
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Compiled Fri 25-Sep-09 08:32 by sasyamal
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: SRR0 = 0x018BA7A0  SRR1 = 0x00029230  SRR2 = 0x017613DC  SRR3 = 0x00021000
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x8C000000  DBSR = 0x00800000
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: CPU Register Context:
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Vector = 0x00002000  PC = 0x01F03708  MSR = 0x00029230  CR = 0x30000095
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: LR = 0x0191B180  CTR = 0x0178AD2C  XER = 0xA0000079
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R0 = 0x00000001  R1 = 0xFFFFFFAC  R2 = 0x00000000  R3 = 0x02B6AAB0
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R4 = 0x0514C3C8  R5 = 0x00000000  R6 = 0x00000001  R7 = 0x00000014
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R8 = 0x778D4B3D  R9 = 0x03860C28  R10 = 0x003C0001  R11 = 0x00000000
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R12 = 0x30000093  R13 = 0x00110000  R14 = 0x03340000  R15 = 0x04D69DF0
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R16 = 0x00000000  R17 = 0x00000000  R18 = 0x04D69E48  R19 = 0x00000001
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R20 = 0x0514C3C8  R21 = 0x0000003C  R22 = 0x0514C3C8  R23 = 0x00000025
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R24 = 0x0514C3C8  R25 = 0x00000025  R26 = 0x003C0001  R27 = 0x73850001
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: R28 = 0x00000025  R29 = 0x003C0001  R30 = 0x03340000  R31 = 0x02B6AAB0
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Stack trace:
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: PC = 0x01F03708, SP = 0xFFFFFFAC
*Mar  1 00:02:28: %PLATFORM-1-CRASHED: Frame 00: SP = 0x00000000    PC = 0x00000000
*Mar  1 00:02:57: %PARSER-6-VIEW_SWITCH: successfully set to view 'root'.
When I remove the switch of the stack , I have the same issue if I connect a PC.
I don't see warnings for hardware failure.
I have crash info but i don't know how to translate it?
Do you have any idea?
Reinstall the IOS?
Thanks in advance for your help
François
7 Replies 7
Leo Laohoo
You've got multiple problems.  Here they are:
1.  Your switch is undergoing a crash-boot-loop.  The switch crashes then tries to create a crashinfo file.  For unknown reasons the flash is full so the switch can't write the crashinfo.  Because of this the switch "crashes" again, reboots and the cycle repeats itself.
2.  You are running 802.1X?  With a buggy IOS 12.2(52)SE.
That's it.
To solve your issue, you need to stop the crash-boot-loop.  In order for you to do this, you'll need to hold down the mode button while the switch is rebooting and go into ROMmon.
Hi Leo,
Thanks for your help.
I deleted files about crash info in the flash to free space and the switch can again write crashinfo.
But the swich is still rebooting...
All my switchs have the IOS version 12.2(52) SE and I didn't have any trouble before this reboot because of this electric cut.
*Mar  1 00:00:32.690: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:00:45.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:46.657: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:00:49: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:49 UTC Mon Mar 1 1993 to 01:00:49 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:00:49: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:00:49 MET Mon Mar 1 1993 to 01:00:49 MET Mon Mar 1 1993, configured from console by console.
*Mar  1 00:01:21: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:01:21: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:01:21: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:01:21: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:01:22: %SYS-5-RESTART: System restarted --
*Mar  1 00:01:22: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:01:23: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:01:23: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.248.7 Port 514 started - CLI initiated
*Mar  1 00:01:26: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.68.160.50 Port 514 started - CLI initiated
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: System previously crashed with the following message:
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Copyright (c) 1986-2009 by Cisco Systems, Inc.
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Compiled Fri 25-Sep-09 08:32 by sasyamal
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: SRR0 = 0x02740EAC  SRR1 = 0x00029230  SRR2 = 0x017613DC  SRR3 = 0x00021000
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x8C000000  DBSR = 0x00800000
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: CPU Register Context:
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Vector = 0x00002000  PC = 0x01F03708  MSR = 0x00029230  CR = 0x35000095
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: LR = 0x0191B180  CTR = 0x0178AD2C  XER = 0xE000007E
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R0 = 0x00000001  R1 = 0xFFFFFFAC  R2 = 0x00000000  R3 = 0x02B6AAB0
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R4 = 0x0514E15C  R5 = 0x00000000  R6 = 0x00000001  R7 = 0x00000014
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R8 = 0x77CFE935  R9 = 0x03860C28  R10 = 0x003C0001  R11 = 0x00000000
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R12 = 0x35000093  R13 = 0x00110000  R14 = 0x03340000  R15 = 0x053703A0
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R16 = 0x00000000  R17 = 0x00000000  R18 = 0x053703F8  R19 = 0x00000001
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R20 = 0x0514E15C  R21 = 0x0000003C  R22 = 0x0514E15C  R23 = 0x00000034
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R24 = 0x0514E15C  R25 = 0x00000034  R26 = 0x003C0001  R27 = 0x73850001
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: R28 = 0x00000034  R29 = 0x003C0001  R30 = 0x03340000  R31 = 0x02B6AAB0
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Stack trace:
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: PC = 0x01F03708, SP = 0xFFFFFFAC
*Mar  1 00:02:22: %PLATFORM-1-CRASHED: Frame 00: SP = 0x00000000    PC = 0x00000000
*Mar  1 00:04:18: %PARSER-6-VIEW_SWITCH: successfully set to view 'root'.
Ok, this is the stack master, right?
Go back to ROMmon and delete all the config.
No I downgraded the switch to member only
I deleted all the configs and the flash was empty.
I copied a new IOS to the flash in rommon mode with the command "copy xmodem flash:"...
I set boot flash with this IOS.
I configured basic configuration with one interface vlan and one port to make tests
But if i connect a port, the switch is rebooting continuously again ...
I think I need to open call at Cisco...
Aijaz Rehman
Download the new image for your cisco Switch from the below link
https://software.cisco.com/download/home/268438038
Use Tera Term, to transfer flash image via Xmodem to cisco switch, download Tera Term tool  its free
Power on your switch while pressing the mode button you will get the ROMMON prompt (switch:)
setup the transfer speed at its high to transfer fast
switch: set BAUD 115200
also change the speed in tera term terminal to do so go to:
set up > serial port> then change the baud rate to 115200 there as well
Give the switch a minute  take into effect, don’t panic when you feel like the screen froze, that happens, if you feel you don't get prompt even after press mode button change this back to 9600 you will get prompt back. but as I said at 9600  it will take long time try to transfer on 115200
then type:
switch: flash_init
switch: copy xmodem: flash:<the image file>
the image file name means the file that you just downloaded kept on  desktop or any folder just copy and paste the name followed by .bin extension
when you hit enter after this command you will see CCCs displayed, then on tera term menu click File > XMODEM > send
browser the file on your desktop or the folder you you have downloaded  .bin file, That’s it! Here the transfer will begin
To verify if .bin files were copied you can type:
switch: dir flash:   and the .bin file should be there.
Depending on the link’s speed it may take up to 40minutes. Once everything is done. Do not forget to set the Baud rate back to 9200:
switch: set BAUD 9600  (if this command didn't accept just type unset Baud it will make it default)
You are almost there, last thing you need to do is type:
switch: boot flash:<.bin file name>
Why would anyone want to use XModem when a switch can boot off a USB flash drive is questionable.
Rutt
Did you read the dump information where it said "FRNTE-E2-12-CS3750-01#"?  3750 = no usb port.
