Issue with 2611
imranraheel
"""Hi;
After I erased my flash i reboot the Router 2611 and tried to Install new IOS from Xmodem (Console) and when I changed the Baud Rate to 115200 and restarted . Hyper Terminal does not display any thing ...Urgent"""
6 Replies 6
Brandon Buffin
Did you change the baud rate in rommon and in hyper terminal as indicated in the following link?
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#download_2620
Brandon
Yes i did the same thing now the display is not coming. Mean i cant see any thing on Hyper terminal
Imran
Have you tried hyperterm at both the speeds of 9600 and 115200?
Rick
Rick
YUp tried both speeds
and did you stop and restart Hyperterm each time that you changed the speed?
Rick
Rick
Yes tried that too
