issue with 6509 sup 720 please help
carl_townshend
Hi all
Im running a 6509 vss pair, I noticed some logs on the system yesterday,looks liek there is an issue with the other supervisor in the chassis! see below
>sh log
Aug 15 23:34:02.793: %SYS-SW1-DFC5-5-RESTART: System restarted --
Aug 16 03:33:47.698: %OIR-SW1_SP-6-REMCARD: Card removed from slot 5, interfaces disabled
>sh module
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1428MTC8
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1428MSZ4
  3   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1130VSGN
  4   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1427M95J
  5    0  Unknown (Other)                        Unknown            Unknown
  6    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1429MY7E
should I re seat the module, or power it off and on??
if I do this it shouldnt impact the system right ?
cheers
Carl
10 Replies 10
Sandeep Choudhary
which IOS versiuon u r running???
hi the version is
12.2(33)SXI4a
Can u paste the whole output of the command:
sh module???
Switch Number:     1   Role:   Virtual Switch Active
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  c84c.75b8.2e08 to c84c.75b8.2e37   3.4   12.2(18r)S1  12.2(33)SXI4 Ok
  2  c84c.75b8.2808 to c84c.75b8.2837   3.4   12.2(18r)S1  12.2(33)SXI4 Ok
  3  001c.58be.5278 to 001c.58be.52a7   1.10  12.2(14r)S5  12.2(33)SXI4 Ok
  4  c84c.7578.aab0 to c84c.7578.aadf   2.4   12.2(18r)S1  12.2(33)SXI4 Ok
  5  0000.0000.0000 to 0000.0000.0000   0.0   Unknown      Unknown      Unknown
  6  0024.14e5.1a18 to 0024.14e5.1a1f   3.2   8.5(4)       12.2(33)SXI4 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1428MRBL  4.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1429MZ9J  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1131W12W  3.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1427LXZF  4.1    Ok
  6  Policy Feature Card 3       VS-F6K-PFC3C       SAL1428MJCM  1.1    Ok
  6  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1427M6HZ  5.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Unknown
  6  Pass
From this output I can not find the module which u r using:
if u r using this;WS-X6748-SFP or WS-X6748-GE-TX  these module
Note: This module is supported only on the  Cisco Catalyst 6500 Series Supervisor Engine 720 running.
Hi There
Slot 5 is the supervisor module, Supervisor Engine 720 10GE (Active)    VS-S720-10G
what should I do here?
cheers
Carl
Hi Carl,
This module is supported only on the Cisco Catalyst 6500 Series Supervisor Engine 720 running Cisco Catalyst OS Version 8.1.2 or Cisco IOS® Software Release 12.2(17a)SX (available in the next few months) and future software releases.
Just try to reset the module and then try again.
Hi there
I have removed the supervisor and plugged it back in.
however is still says unknown when I do a show module.
could this be a faulty card? is there any tests I can run?
cheers
Carl
If your current active supervisor card is running SXI4a, what IOS is the other supervisor running (the one in slot 5)?
The IOS should be the same or the supervisor card in slot 5 will go into ROMmon.
cyf6759279
I have this problem too,it has been solved?
