Issue with ACL configs on Switch
Spockles
Hi there,
Wondering if any of you folks can help me. I was recently working in the virtual space with Vyatta routers and wanted to move to a hardware solution using a 3550/3650 switch. I have an isue where I cannot connect to any of the networks setup on my switch. Pings to certain networks return
From 192.168.101.254 icmp_seq=36 Packet filtered
From 192.168.101.254 icmp_seq=38 Packet filtered
From 192.168.101.254 icmp_seq=43 Packet filtered
From 192.168.101.254 icmp_seq=48 Packet filtered
From 192.168.101.254 icmp_seq=53 Packet filtered
Pings to the 20.20.20.x network return network unreachable and the same for the 30.30.30.x
I cannnot access any of the services on 20.20.20.x or 30.30.30.x
Any help is appreciated
The following is my current config
hostname switch
ip subnet-zero
ip routing
interface FastEthernet0/1
 switchport access vlan 101
 switchport mode access
 no ip address
 exit
interface FastEthernet0/2
 switchport access vlan 102
 no ip address
 exit
interface FastEthernet0/3
 switchport access vlan 103
 no ip address
 exit
interface FastEthernet0/4
 switchport access vlan 104
 no ip address
 exit
interface FastEthernet0/5
 switchport access vlan 105
 no ip address
 exit
interface FastEthernet0/6
 switchport access vlan 106
 no ip address
 exit
interface FastEthernet0/7
 switchport access vlan 107
 no ip address
 exit
interface FastEthernet0/8
 switchport access vlan 108
 no ip address
 exit
interface FastEthernet0/9
 switchport access vlan 109
 no ip address
 exit
interface FastEthernet0/10
 switchport access vlan 110
 no ip address
 exit
interface FastEthernet0/11
 switchport access vlan 111
 no ip address
 exit
interface FastEthernet0/12
 switchport access vlan 112
 no ip address
 exit
interface FastEthernet0/13
 switchport access vlan 113
 no ip address
 exit
interface FastEthernet0/14
 switchport access vlan 114
 no ip address
 exit
interface FastEthernet0/15
 switchport access vlan 115
 no ip address
 exit
interface FastEthernet0/16
 switchport access vlan 116
 no ip address
 exit
interface FastEthernet0/17
 switchport access vlan 117
 no ip address
 exit
interface FastEthernet0/18
 switchport access vlan 118
 no ip address
 exit
interface FastEthernet0/19
 no ip address
interface FastEthernet0/20
 no ip address
interface FastEthernet0/21
 switchport access vlan 200
 no ip address
 exit
interface FastEthernet0/22
 no ip address
 exit
interface FastEthernet0/23
 no ip address
 exit
interface FastEthernet0/24
 no ip address
 exit
interface FastEthernet0/25
 no ip address
interface FastEthernet0/26
 no ip address
 exit
interface FastEthernet0/27
 switchport access vlan 300
 no ip address
 exit
interface FastEthernet0/28
 no ip address
 exit
interface FastEthernet0/29
 no ip address
 exit
interface FastEthernet0/30
 no ip address
 exit
interface FastEthernet0/31
 no ip address
interface FastEthernet0/32
 no ip address
interface FastEthernet0/33
 switchport access vlan 400
 no ip address
 exit
interface FastEthernet0/34
 no ip address
 exit
interface FastEthernet0/35
 no ip address
 exit
interface FastEthernet0/36
 no ip address
 exit
interface FastEthernet0/37
 no ip address
interface FastEthernet0/38
 no ip address
interface FastEthernet0/39
 switchport access vlan 500
 no ip address
 exit
interface FastEthernet0/40
 no ip address
 exit
interface FastEthernet0/41
 no ip address
 exit
interface FastEthernet0/42
 no ip address
 exit
interface FastEthernet0/43
 no ip address
 exit
interface FastEthernet0/44
 no ip address
 exit
interface FastEthernet0/45
 no ip address
interface FastEthernet0/46
 no ip address
interface FastEthernet0/47
 no ip address
interface FastEthernet0/48
 no ip address
interface GigabitEthernet0/1
 no ip address
interface GigabitEthernet0/2
 no ip address
interface Vlan1
 no ip address
 shutdown
interface range FastEthernet0/1 - 20
 no shut
 exit
interface range FastEthernet0/21 - 24
 no shut
 exit
interface range FastEthernet0/25 - 48
 no shut
 exit
interface Vlan101
 ip address 192.168.101.254 255.255.255.0
 ip access-group p1 in
 exit
interface Vlan102
 ip address 192.168.102.254 255.255.255.0
 ip access-group p2 in
interface Vlan103
 ip address 192.168.103.254 255.255.255.0
 ip access-group p3 in
 exit
interface Vlan104
 ip address 192.168.104.254 255.255.255.0
 ip access-group p4 in
interface Vlan105
 ip address 192.168.105.254 255.255.255.0
 ip access-group p5 in
 exit
interface Vlan106
 ip address 192.168.106.254 255.255.255.0
 ip access-group p6 in
interface Vlan107
 ip address 192.168.107.254 255.255.255.0
 ip access-group p7 in
 exit
interface Vlan108
 ip address 192.168.108.254 255.255.255.0
 ip access-group p8 in
interface Vlan109
 ip address 192.168.109.254 255.255.255.0
 ip access-group p9 in
 exit
interface Vlan110
 ip address 192.168.110.254 255.255.255.0
 ip access-group p10 in
 exit
interface Vlan111
 ip address 192.168.111.254 255.255.255.0
 ip access-group p11 in
 exit
interface Vlan112
 ip address 192.168.112.254 255.255.255.0
 ip access-group p12 in
 exit
interface Vlan113
 ip address 192.168.113.254 255.255.255.0
 ip access-group p13 in
 exit
interface Vlan114
 ip address 192.168.114.254 255.255.255.0
 ip access-group p14 in
 exit
interface Vlan115
 ip address 192.168.115.254 255.255.255.0
 ip access-group p15 in
 exit
interface Vlan116
 ip address 192.168.116.254 255.255.255.0
 ip access-group p16 in
 exit
interface Vlan117
 ip address 192.168.117.254 255.255.255.0
 ip access-group p17 in
 exit
interface Vlan118
 ip address 192.168.118.254 255.255.255.0
 exit
interface Vlan200
 ip address 20.20.20.254 255.255.255.0
 exit
interface Vlan300
 ip address 30.30.30.254 255.255.255.0
 exit
interface Vlan400
 ip address 40.40.40.254 255.255.255.0
 exit
interface Vlan500
 ip address 11.11.11.254 255.255.255.0
 exit
ip classless
ip http server
ip access-list extended p1
 permit tcp 20.20.20.0 0.0.0.255 192.168.101.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.101.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.101.0 0.0.0.255 eq 443
 permit tcp 192.168.101.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.101.0 0.0.0.255
 permit ip 192.168.101.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p2
 permit tcp 20.20.20.0 0.0.0.255 192.168.102.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.102.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.102.0 0.0.0.255 eq 443
 permit tcp 192.168.102.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.102.0 0.0.0.255
 permit ip 192.168.102.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p3
 permit tcp 20.20.20.0 0.0.0.255 192.168.103.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.103.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.103.0 0.0.0.255 eq 443
 permit tcp 192.168.103.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.103.0 0.0.0.255
 permit ip 192.168.103.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p4
 permit tcp 20.20.20.0 0.0.0.255 192.168.104.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.104.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.104.0 0.0.0.255 eq 443
 permit tcp 192.168.104.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.104.0 0.0.0.255
 permit ip 192.168.104.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
 ip access-list extended p5
 permit tcp 20.20.20.0 0.0.0.255 192.168.105.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.105.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.105.0 0.0.0.255 eq 443
 permit tcp 192.168.105.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.105.0 0.0.0.255
 permit ip 192.168.105.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p6
 permit tcp 20.20.20.0 0.0.0.255 192.168.106.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.106.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.106.0 0.0.0.255 eq 443
 permit tcp 192.168.106.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.106.0 0.0.0.255
 permit ip 192.168.106.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p7
 permit tcp 20.20.20.0 0.0.0.255 192.168.107.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.107.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.107.0 0.0.0.255 eq 443
 permit tcp 192.168.107.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.107.0 0.0.0.255
 permit ip 192.168.107.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p8
 permit tcp 20.20.20.0 0.0.0.255 192.168.108.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.108.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.108.0 0.0.0.255 eq 443
 permit tcp 192.168.108.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.108.0 0.0.0.255
 permit ip 192.168.108.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p9
 permit tcp 20.20.20.0 0.0.0.255 192.168.109.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.109.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.109.0 0.0.0.255 eq 443
 permit tcp 192.168.109.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.109.0 0.0.0.255
 permit ip 192.168.109.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p10
 permit tcp 20.20.20.0 0.0.0.255 192.168.110.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.110.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.110.0 0.0.0.255 eq 443
 permit tcp 192.168.110.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.110.0 0.0.0.255
 permit ip 192.168.110.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p11
 permit tcp 20.20.20.0 0.0.0.255 192.168.111.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.111.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.111.0 0.0.0.255 eq 443
 permit tcp 192.168.111.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.111.0 0.0.0.255
 permit ip 192.168.111.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p12
 permit tcp 20.20.20.0 0.0.0.255 192.168.112.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.112.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.112.0 0.0.0.255 eq 443
 permit tcp 192.168.112.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.112.0 0.0.0.255
 permit ip 192.168.112.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
 ip access-list extended p13
 permit tcp 20.20.20.0 0.0.0.255 192.168.113.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.113.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.113.0 0.0.0.255 eq 443
 permit tcp 192.168.113.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.113.0 0.0.0.255
 permit ip 192.168.113.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p14
 permit tcp 20.20.20.0 0.0.0.255 192.168.114.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.114.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.114.0 0.0.0.255 eq 443
 permit tcp 192.168.114.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.114.0 0.0.0.255
 permit ip 192.168.114.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p15
 permit tcp 20.20.20.0 0.0.0.255 192.168.115.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.115.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.115.0 0.0.0.255 eq 443
 permit tcp 192.168.115.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.115.0 0.0.0.255
 permit ip 192.168.115.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p16
 permit tcp 20.20.20.0 0.0.0.255 192.168.116.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.116.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.116.0 0.0.0.255 eq 443
 permit tcp 192.168.116.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.116.0 0.0.0.255
 permit ip 192.168.116.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p17
 permit tcp 20.20.20.0 0.0.0.255 192.168.117.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.117.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.117.0 0.0.0.255 eq 443
 permit tcp 192.168.117.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.117.0 0.0.0.255
 permit ip 192.168.117.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
ip access-list extended p18
 permit tcp 20.20.20.0 0.0.0.255 192.168.118.0 0.0.0.255 eq www
 permit tcp 20.20.20.0 0.0.0.255 192.168.118.0 0.0.0.255 eq 8080 established
 permit tcp 20.20.20.0 0.0.0.255 192.168.118.0 0.0.0.255 eq 443
 permit tcp 192.168.118.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8080
 permit ip 30.30.30.0 0.0.0.255 192.168.118.0 0.0.0.255
 permit ip 192.168.118.0 0.0.0.255 30.30.30.0 0.0.0.255
 deny   ip any any
 exit
access-list 120 permit tcp 20.20.20.0 0.0.0.255 30.30.30.0 0.0.0.255 eq 8181 established
access-list 130 permit tcp 30.30.30.0 0.0.0.255 20.20.20.0 0.0.0.255 eq 8181
access-list 140 permit tcp any any eq 8080
access-list 140 permit tcp any any eq www
no cdp advertise-v2
line con 0
line vty 5 15
monitor session 1 source vlan 1 - 500 rx
monitor session 1 destination interface Fa0/47
monitor session 2 source vlan 1 - 500 rx
monitor session 2 destination interface Fa0/48
end
5 Replies 5
Your Ping to 192.168.100.254 failed because it is filtered by ACL. Either you need to ping from addresses allowed in the ACL (address space 30.30.30.0/24), or modify the ACL as follows:
permit icmp any any
deny ip any any
exit
You need to modify the other ACLs as well if you want to run PING.
For 20.20.20.x and 30.30.30.x, could you check if you have routes in the routing table?
HTH,
Meheretab
HTH,
Meheretab
Thanks for reply. However I'm not sure this is what I want. I might have phrased my question wrong.
Hi Spockles,
Your ACL configuration is incorrect.
Can you please tell me the exact source and destination to which you want to allow traffic?
After that we can modify the ACL then you can test.
Please also make sure the gateway configured on the servers is correct.
Spooster IT Services Team
Thanks for the reply. So there was an issue with gateways on the servers. I think my initial question did not tell the whole story of what I require.
So the 192.168.101-120.0 Vlans need http access to 20.20.20.0 network. They should have full access to the 30.30.30.0 network. Traffic from 30.30.30.0 to 20.20.20.0 should only be over the port specified in acl 120 and 130. Ping from 30.30.30.0 to 20.20.20.0 should not be allowed. Traffic from 30.30.30.0 and 20.20.20.0 should only be allowed over port 514. This I have not added in yet.
Thanks for help
Hello
I haven't checked each individual acl but It seems at first glance of this config your acl's are assigned in the wrong direction.
SVI RACLS have a logic of:
IN = From within the vlan to Outside
OUT= from Outside into vlan
Lastly ACLs 120/130/140 are not assigned to anything if this is the case Id removed them for clarity
res
Paul
Kind Regards
Paul
