Issue with configuring Port-channel on CISCO3750G-Stacked
Facing a issue with configuring Port-Channel between stacked switches. (Two CISCO3750G)
After configured Port-channel, While both Interfaces are up, I'm unable to ping the host (connected in configured ports).
If we remove any one cable, we are getting connection to host.
(We have tried with reload the switches - No result)
Requesting help regarding this
i wouldn't change it to active if you are not sure if the compter on the other side supports LACP
11 Replies 11
lmediavilla
What I understand is that you have a port channel using ports in differents switches of the same stack
what does the "show etherchannel summary" command shows? that can give you an idea of the problem.
Kind regards
Sandeep Choudhary
Hi Ramesh,
1. Can you please post the config of both port and port channel.
2. Put all result of : sh int port-channel ?
Sh int port1
Sh int port 2
Yes. Port channel in different switches of the same stack.
SW#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 16
Number of aggregators:           16
Group  Port-channel  Protocol    Ports
21     Po21(SU)         -        Gi1/0/2(P)  Gi2/0/2(D)
22     Po22(SU)         -        Gi1/0/1(P)  Gi2/0/1(D)
24     Po24(SU)         -        Gi1/0/4(P)  Gi2/0/4(P)
25     Po25(SU)        LACP      Gi1/0/5(P)  Gi2/0/5(P)
26     Po26(SU)        LACP      Gi1/0/6(P)  Gi2/0/6(P)
27     Po27(SU)        LACP      Gi1/0/7(P)  Gi2/0/7(P)
28     Po28(SU)        LACP      Gi1/0/8(P)  Gi2/0/8(P)
interface Port-channel21
switchport access vlan 20
switchport mode access
interface GigabitEthernet2/0/2
shutdown
speed 1000
duplex full
channel-group 21 mode on
spanning-tree portfast
interface GigabitEthernet1/0/2
speed 1000
duplex full
SICDC_L3_001#sh int gigabitEthernet 1/0/2
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is b414.890c.df82 (bia b414.890c.df82)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:51, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 59000 bits/sec, 37 packets/sec
  5 minute output rate 65000 bits/sec, 35 packets/sec
     2353816 packets input, 362034061 bytes, 0 no buffer
     Received 92183 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     2223667 packets output, 360707963 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
SICDC_L3_001#sh int gigabitEthernet 2/0/2
GigabitEthernet2/0/2 is administratively down, line protocol is down (disabled)
  Hardware is Gigabit Ethernet, address is 0023.0530.8b02 (bia 0023.0530.8b02)
  Description: Portchannel-PLATINUM
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
Note: currently I have manually shutdown the interface Gi2/0/2. For server  availability. If I put 'no sh' command in Gi2/0/2, server connectivity  will be lost.
Hi Ramesh,
Can you try to use channel-group 21 mode active on both ports.
shutdown
speed 1000
duplex full
speed 1000
duplex full
Maybe this is the reason why Gig 2/0/2 is not joining the Port-Channel 21.
lmediavilla
What do you have on the other side of the etherchannel?
Can the computer on the other side of the etherchannel have any problem with the network teaming?
Can the other side supports LACP (better because you will get LACP keep alives)
i will write spanning-tree protfast on the portchannel, the config should be the same from the physical and the portchannel.
Change that and check if the port forwards traffic.
Kind regards
devils_advocate
Level 7
Level 7
Can you post the config from the two ports on the other side of the link?
its the same, two ports with the same config and channel-grup #### mode active (could be active one side and passive in the other or both active, personally I prefer active active)
and then you configure the interface port-channel ###
once you have the port-channel you mustn't deal with physical interfaces, all config must be done on the port-channel interface.
Kind regards
To confirm its an issue with cros stack port-channel issue, can you move both the interface to the same switch in the stack and bundle it?
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi All,
This issue is resolved now.
1) I have changed Server's Binding mode to support LACP.
2) Changed the Switch Interfaces configuration with channel-group 22 mode passive
Thank you for support.
Ramesh Balachandran
