issue with connected interface
Mark Malone
Hey
we have a SVI interface that will be a mgmt interface on a VSS switch , we will be sourcing all mgmt traffic from that vlan interface.
The issue were facing is traffic to reach any device must first go to the firewall as a security policy and then hit the SVI on each device
but the VSS is in the path of the firewall so this one switch has a connected route so not matter what way i try to influence it when i trace to the SVI for the VSS switch its stops on the VSS switch which is what you would expect as thats where it is. We need to break the logical thinking of the switch and allow traffic for that particular interface when we trace to it, to still pass through the switch hit the firewall and then come back.I know its not ideal but thats what we need.
Is there any way to manipulate connected routes that i can make them route upstream to the firewall even though its locally owned
tried a vrf , manipulate statics but all the time route table says its locally connected
The issue is only with the VSS  switch the design has worked for all other remote and local switches so we cant really change the whole design for one switchs mgmt traffic
8 Replies 8
Jon Marshall
Hi Mark
So you have a switch that is in the same IP subnet as the SVI on the VSS and for that switch to get to the firewall it has to go via the VSS switch which means it just stops there.
And you want it to go out to the firewall and then back ?
Is the firewall interface IP in the same IP subnet as the VSS SVI ?
And how do all the other switches work ie.are they in the same IP subnet as the VSS SVI ?
Could you clarify the IP addressing.
Presumably the switch is connected via a trunk ie. I am assming PBR on the VSS switch is not possible because the traffic enters on the management vlan ie. the first L3 interface it hits is the management SVI ?
Jon
Hi Jon
thanks for the reply
basically we have given each switch an ip address in range 172.21.226.0/23 , the gateway for this subnet is on the firewall 172.21.226.1 , the vss has an ip of .189 , the issue is the jumpbox we use to access the switches is behind the vss so it goes jumpbox - l2 switch - vss - firewall  as the path
when we trace to 172.21.226.189 it stops at the vss which would be correct as thats where the ip is set but we need it even though its a connected interface to go through the vss up to the firewall and then back to the vss , the reason for this is security have said that all mgmt traffic needs to first go to the firewall to be processed first (we have out of band switches directly connected to a vdom on the firewall all mgmt traffic from each switch is set as a source of that vlan interface)
all other switches are either directly connected to the oob switches/firewall and work fine there layer 2 , it just seems to be an issue with the vss as its routing, i tried set the vlan interface in its own vrf and pointed it to the firewall but it still choses the most specific local connected interface the vlan so i cant get the traffic to go to the firewall first.
hopefully i made that clear there and im not sure if this is possible even as were tring to override a connected interface and make it go to the fw first an then back
And you want it to go out to the firewall and then back ? Yes exactly
Is the firewall interface IP in the same IP subnet as the VSS SVI ? Yes both in /23 network
Presumably the switch is connected via a trunk ie. I am assming PBR on the VSS switch is not possible because the traffic enters on the management vlan ie. the first L3 interface it hits is the management SVI ? Yes trioed pbr but not even getting a hit on the acl , tried extended and standard but same result
Mark
Thanks for clarifying.
Just one other question and I suspect I know the answer but the jumpbox is presumably in the management vlan subnet ?
Jon
Thanks Jon i just found the issue , theres an old DNS entry in one of the system so whenever i traced by name i was just hitting vss directly from jumbox, when i use ip address and trace direct to that it takes the correct path hits the firewall first and then the VSS interface so the vrf is actually working as it should be 🙂 were removing the dns entry now so it should work by name too
Mark
Thanks for letting me know.
I was thinking VRFs might be a solution but could't understand why it wasn't working 🙂
Jon
Just out of interest is the jumpbox in a separate IP subnet ?
I am assuming so otherwise even with a VRF I'm not sure how you got it working.
Jon
Hi yes jumpbox is completely seperate subnet 172.21.2.x
Thanks, makes sense now.
Jon
