Issue with DHCP Pool Name Using Variables in Activity Wizard
kovacsl
Hi everyone,
I'm having trouble with Cisco Packet Tracer's Activity Wizard while trying to configure a DHCP pool using a variable for the pool name. I'm using the command ip dhcp pool [[pool_name]], but the variable [[pool_name]] is not being replaced with the actual values during execution.
I've correctly set up the variable in the Variable Manager, and it works fine for other parts of the configuration. However, when I apply it to the DHCP pool command, it doesn't seem to swap out the placeholder for the actual value.
Has anyone else faced this issue or knows how to resolve it? Any help would be appreciated!
Thanks!
Martin L
if it is old, if Packet Tracer's Activity Wizard was made for previous versions of PT, it may not work in the latest version;
Also, check speeling , upper -case letters, etc. Are Pool name and viarables correct ?
you could attach your PT file here - must be in zip format
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
