Issue with intervlan routing
bct0109
Community Member
I have a wired subnet (VLAN 1) that has SVI 192.168.1.1  The att modem is 192.168.1.254
I have a wireless subnet (VLAN 2) that has SVI 192.168.86.254.  The wireless router is 192.168.86.1
From the Nexus 3K I can reach all devices
I am unable to ping between devices between VLAN 1 and VLAN 2 and vice versa
ip route 192.168.1.0/24 Vlan1 192.168.1.254
ip route 192.168.86.0/24 Vlan2 192.168.86.1
vlan 1
vlan 2
name wireless
vlan 3
name wired
spanning-tree vlan 1 priority 24576
service dhcp
ip dhcp relay
ip dhcp relay information option
ipv6 dhcp relay
vrf context management
ip route 0.0.0.0/0 192.168.1.1
no port-channel load-balance resilient
interface Vlan1
no shutdown
mtu 9216
management
no ip redirects
ip address 192.168.1.1/24
ip dhcp relay address 192.168.1.2
ip dhcp relay address 192.168.1.254
interface Vlan2
no shutdown
mtu 9216
management
no ip redirects
ip address 192.168.86.254/24
rwolf1
Frequent Visitor
Frequent Visitor
Hey bct0109,
Have you enabled "ip routing" on the Nexus? Let me know if this is able to help!
bct0109
Community Member
Which context should I run it from?  Global context requires more syntax.  Do my default routes look correct?
MBNET-3048(config)# ip routing
event-history internal multicast
MBNET-3048(config)# ip routing ?
event-history Configure routing event log
internal Commands for internal use
multicast Configure multicast
rwolf1
Frequent Visitor
Frequent Visitor
Running it from global without any syntax should be sufficient.
Additionally, is there a reason you’ve specified two DHCP relays on VLAN1? Is all ports on your switch routed ports, or is traffic being forwarded through any switch ports?
sanderhondius
Frequent Visitor
Frequent Visitor
On the DHCP server have you set the default router address (DHCP option 3) within the DHCP pools?
