Issue with Iomega NAS connected to LACP Port-Channel
Googleface76
I have configured my Iomega Ix4-200d NAS wth 2 x aggregated 802.3ad nics and the switch appears to be configured as I expect with an LACP port-channel. However, I am unable to ping my NAS devices IP address (192.168.2.100) from any clients on my network, I can ping this from the switch itself.
I have a linksys wireless router that acts as my router and this is running DD-WRT firmware, the router has a static route configure for the vLANs I use. The NAS device is on vLAN 3 and the static route on the router is
Destination LAN Net: 192.168.2.0
SM: 255.255.255.0
DG: 192.168.0.10 - (This is the IP address of my switch)
I have a Cisco 3750G switch running Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE2 and this my config.
NAS device IP config:
IP: 192.168.2.100
SM: 255.255.255.0
DG: 192.168.2.0
Switch Port Config:
> sh etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 6
Number of aggregators:           6
Group  Port-channel  Protocol    Ports
1      Po1(SD)          -
2      Po2(SD)          -
5      Po5(SD)         PAgP      Gi1/0/12(D)
10     Po10(SD)         -
12     Po12(SD)        LACP      Gi1/0/11(P) Gi1/0/13(P)
20     Po20(SD)         -        Gi1/0/19(D)
>sh run int port-channel 12
Building configuration...
Current configuration : 149 bytes
interface Port-channel12
description IOMEGA NAS Gi/1/0/11_Gi1/0/13
switchport access vlan 3
switchport mode access
switchport nonegotiate
end
>sh run int gi1/0/11
Current configuration : 200 bytes
interface GigabitEthernet1/0/11
channel-group 12 mode active
spanning-tree portfast
spanning-tree bpdufilter enable
end
sh run int gi1/0/13
Current configuration : 226 bytes
interface GigabitEthernet1/0/13
end
>sh int port-channel 12
Port-channel12 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
  Description: IOMEGA NAS Gi/1/0/11_Gi1/0/13
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicast)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
>sh int gi1/0/11
GigabitEthernet1/0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001b.0cff.060b (bia 001b.0cff.060b)
  MTU 9000 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
>sh int gi1/0/13
GigabitEthernet1/0/13 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001b.0cff.060d (bia 001b.0cff.060d)
  Description: esx1 Vlan 10
Can someone please help me out.
Many Thanks
Scott
Reza Sharifi
Can you clarify a couple of things?
first:
SM: 255.255.255.0
The default gateway is not in the same subnet as the LAN Net
second:
IP: 192.168.2.100
SM: 255.255.255.0
DG: 192.168.2.0
the default gateway cannot be 192.168.2.0
Hi Reza,
Thanks for the reply.
Before I begin I need you to know that I am not a network engineer and I did not configure my switch, this was done by a friend of mine who works in networks.
The config works fine if the switchports are joined to to vLAN 3 only and the NAS device runs on a single nic.
If I change the static route to have a DG: 192.168.2.1 I cannot ping 192.168.2.100 even when the nics are in the vLAN 3 only and not configured in an LACP port-channel.
I assume that my friend must have configured my switch to be a router as well if everything works and the DG of my static route is 192.168.0.10.
What information do you need me to provide to troubleshoot this please.
This is the routing info.
GARGRAVE-SW1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C    192.168.0.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via 192.168.0.1
192.168.0.1 is the ip address of my Linksys - DD-WRT wireless router.
Scott
