Issue with ISP and Cisco 1841 router
rafabricant
I have a Cisco 1841 router and a Cisco 2950 switch. I am unable to get out of my network. I have ran various scripts and still no luck. Here are my Scripts maybe someone see what im missing. Thanks
Cisco 1841:
Int fa0/0
no shutdown
exit
int fa0/0.99
description  Native VLAN 99
encapsulation dot1q 99 native
ip address 172.16.99.1 255.255.255.224
exit
int fa0/0.100
description Home-Network
encapsulation dot1q 100
ip address 172.16.100.1 255.255.255.0
ip nat inside
no snmp trap link-status
exit
int fa0/0.200
description Server
encapsulation dot1q 200
ip address 172.16.200.1 255.255.2550
ip nat inside
exit
int fa0/1
Description to Modem
ip address 192.168.1.2 255.255.255.0
ip nat inside
exit
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip nat inside source list home interface fastethernet0/1 overload
ip nat inside source list server interface fastethernet0/1 overload
Cisco 2950:
VLAN 100
name Home-Network
VLAN 200
name Server
VLAN 99
name Management
exit
int vlan 99
ip address 172.16.99.2 255.255.255.224
exit
int fa0/1
description Trunk to router
switchport mode trunk
exit
int range fa0/2 - 8
description Home-Network VLAN 100
switchport mode access
switchport access vlan 100
exit
int range fa0/9 - 12
description sales VLAN 200
switchport access vlan 200
exit
8 Replies 8
paolo bevilacqua
Outside interface needs nat outside, not inside.
Note these are configurations not scripts.
ok thank you, I have switched int fa0/1 to ip nat outside but still can not get out of my network.
Use only one global NAT command and check related ACL.
rafabricant
I'm not sure if im following. On fa0/1 run the command of
ip nat outside source static 192.168.1.1 192.168.1.2
Here is my Run Command if this helps.
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.99
encapsulation dot1Q 99 native
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip nat inside
interface FastEthernet0/0.200
description Server
encapsulation dot1Q 200
ip address 172.16.200.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
description to Modem
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip nat inside source list home interface FastEthernet0/1 overload
ip nat inside source list server interface FastEthernet0/1 overload
control-plane
line con 0
login
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit icmp any any
access-list 101 permit tcp any any established
access-list 101 permit tcp any any ack
access-list 101 permit tcp any any psh
access-list 101 permit udp any eq 53 any
access-list 101 permit tcp any eq53
i am unsure with acl, i have never done this before. please let me know if this is correct. and i am still unable to get outside my network.
Your best choice is to refer to documents or examples of which there are many.
I used my CCNA Portable Command guide and used the following commands but still nothing
ip nat pool home 192.168.1.1 192.168.1.2 netmask 0.0.0.255
access-list 1 permit 172.16.100.0 0.0.0.255
ip nat pool server 192.168.1.1 192.168.1.2 netmask 0.0.0.255
access-list 1 permit 192.16.200.0 0.0.0.255
