issue with LACP
jkay18041
Level 3
Level 3
Ive created two port-channel groups and one of them won't work It keeps showing that they are not-in-bndl and sometimes there are other erros.
Can someone look at one side of my config and see if I have an issue on it? I'll try to get the other config from the other end but I don't have a console cable hooked to it at the moment and I don't have access to the management vlan via VPN.
Server_Rack#show run
Building configuration...
Current configuration : 7780 bytes
version 12.2
no service pad
hostname Server_Rack
boot-start-marker
boot-end-marker
no logging console
username j
no aaa new-model
switch 1 provision ws-c3750e-48pd
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip domain-name
crypto pki trustpoint TP-self-signed-4
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-4
crypto pki certificate chain TP-self-signed-
certificate self-signed 01
30820253 308201BC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
3676E 65642D43 65727469 66696361 74652D34 32373531
33393332 3
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface Port-channel5
description MDF to SERVER RACK
switchport trunk native vlan 99
switchport mode trunk
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport access vlan 99
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport access vlan 2
no vtp
spanning-tree portfast
interface GigabitEthernet1/0/6
no vtp
interface GigabitEthernet1/0/7
no vtp
interface GigabitEthernet1/0/8
no vtp
interface GigabitEthernet1/0/9
no vtp
interface GigabitEthernet1/0/10
no vtp
interface GigabitEthernet1/0/11
no vtp
interface GigabitEthernet1/0/12
no vtp
interface GigabitEthernet1/0/13
no vtp
interface GigabitEthernet1/0/14
no vtp
interface GigabitEthernet1/0/15
no vtp
interface GigabitEthernet1/0/16
no vtp
interface GigabitEthernet1/0/17
no vtp
interface GigabitEthernet1/0/18
no vtp
interface GigabitEthernet1/0/19
no vtp
interface GigabitEthernet1/0/20
no vtp
interface GigabitEthernet1/0/21
no vtp
interface GigabitEthernet1/0/22
no vtp
interface GigabitEthernet1/0/23
no vtp
interface GigabitEthernet1/0/24
no vtp
interface GigabitEthernet1/0/25
no vtp
interface GigabitEthernet1/0/26
no vtp
interface GigabitEthernet1/0/27
no vtp
interface GigabitEthernet1/0/28
no vtp
interface GigabitEthernet1/0/29
no vtp
interface GigabitEthernet1/0/30
no vtp
interface GigabitEthernet1/0/31
no vtp
interface GigabitEthernet1/0/32
no vtp
interface GigabitEthernet1/0/33
no vtp
interface GigabitEthernet1/0/34
no vtp
interface GigabitEthernet1/0/35
no vtp
interface GigabitEthernet1/0/36
no vtp
interface GigabitEthernet1/0/37
no vtp
interface GigabitEthernet1/0/38
no vtp
interface GigabitEthernet1/0/39
no vtp
interface GigabitEthernet1/0/40
no vtp
interface GigabitEthernet1/0/41
no vtp
interface GigabitEthernet1/0/42
no vtp
interface GigabitEthernet1/0/43
no vtp
interface GigabitEthernet1/0/44
no vtp
interface GigabitEthernet1/0/45
channel-group 5 mode active
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
no vtp
interface GigabitEthernet1/0/50
no vtp
interface GigabitEthernet1/0/51
no vtp
interface GigabitEthernet1/0/52
no vtp
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.236 255.255.255.0
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
line vty 5 15
exec-timeout 30 0
login local
transport input ssh
end
I'm assuming the other end should match.
Thank you for your help!
Julio E. Moisa
Your configuration looks fine, except you need to remove this line under the interface members: spanning-tree portfast
It can create Layer 2 loops and not recommend to be used under trunk interfaces.
Now if you want to set up them again, you can use:
no int po 5
default interface range g1/0/45-48
shut
no shut
int po 5
switchport trunk encap dot1q
switchport trunk native vlan 999
no shut
 Then you can check the status using
show etherchannel summary
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
jkay18041
Level 3
Level 3
As of now the ports are unhooked but here is the show etherchannel 3 output
Server_Rack#show etherchannel 5 detail
Group state = L2
Ports: 4 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi1/0/45
Port state = Down Not-in-Bndl
Channel group = 5 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po5
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi1/0/45 SA down 32768 0x5 0x0 0x12E 0x45
Age of the port in the current state: 0d:00h:45m:47s
Port: Gi1/0/46
Local information:
Gi1/0/46 SA down 32768 0x5 0x0 0x12F 0x45
Age of the port in the current state: 0d:00h:48m:35s
Port: Gi1/0/47
I guess you configured the Etherchannel separately from the interfaces. Since it is a layer 2 Etherchannel, you can configure it as follows:
First remove all of your Etherchannel config, and
default interface range Gi1/0/45 - 48
spanning-tree portfast trunk
end
The other end also needs to be configured. It could be active or passive.
HTH,
Meheretab
HTH,
Meheretab
So after deleting the etherchannel and resetting those ports to defaults I just need to set up each port like I want it and add the etherchannel to it and do mode active on at least one side? I don't need to setup the etherchannel itself such as
port-channel 5
Julio E. Moisa
no int po 5
shut
no shut
int po 5
no shut
If I want to give this a try would this work to do...
Switch A and Switch B are hooked up with a single cable both switchport access vlan 2, no other vlans going between them.
If I setup a the port channel but did a trunk such as
switchport trunk allowed vlan 10,20 this would work without creating a loop because it's layer 2 and since vlan 2 isn't allowed on the trunk there would be no loop correct?
It should not be a risk, it will be a second port channel, right?
if you filter you trunk interfaces with: switchport trunk allow vlan 10,20  the vlan 2 and other created locally will not be send frames through this link.
If your spanning tree is configured properly you should have any problem.
Well since I had an issue with that port channel it would be the only port channel on switch b. I hooked switch A and B up together with a single untagged access vlan 2 port. Switch A has another port channel but it goes to a different switch stack and works fine. It was just this one port channel between switch A and B that kept giving me fits. But makes sense since I didn't set the ports to defaults before I created the port channel
