Issue with logging to the device after wrongly configured TACACS
Hell All,
We are unable to login to the device after we wrongly configured AAA on Cisco 881 Router and unfortunately we have saved the configuration.
Can you please help to either remove the remove the TACACS configuration or how we can reset the password without erasing the configuration?
Thanks a lot in advance for your help.
Thiyagu
Jeff Van Houten
Level 5
Level 5
Look for password recovery. Not difficult if you have console access.
