Issue with string on Cisco Load balancer
vikramfonseca
Hi guys,
We had a bit of a problem understanding what happens when there's a string mismatch on a load balancer esp because we were required to create a post incident report.
Pls note the correct sample config on a LB;
service WPST01
ip address 192.168.120.61
keepalive type HTTP
string WPST01
active
service WPST02
ip address 192.168.120.63
keepalive type HTTP
string WPST02
active
service WPST03
ip address 192.168.120.65
keepalive type HTTP
string WPST03
active
!*************************** OWNER ***************************
owner XXX
content PORTAL
protocol tcp
port 80
balance leastconn
add service WPST01
add service WPST02
add service WPST03
vip address 192.168.120.50
advanced-balance arrowpoint-cookie
active
What I'd like to know is what would happen as far as the flow of information is concerned, setting up on connections, maintaining sessions, etc if the config was changed to;
service WPST01
keepalive type HTTP
string WPST02
active
service WPST02
keepalive type HTTP
string WPST02
active
service WPST03
keepalive type HTTP
string WPST03
active
owner XXX
content PORTAL
protocol tcp
port 80
balance leastconn
add service WPST01
add service WPST02
add service WPST03
active
Now, service 1 has a string that references a cookie for service 2.
Looking forward to hearing from you soon.
smahbub
Level 6
Level 6
when the service name does not match with the string name the loadbalancing will not happen properly due to mismatch of the strings and an error stating the string mismatch will be given.The strings should match for proper loadbalancing to take place.
Hey smahbub, thanks for replying. I agree with the reason you've given but I'd also like to know how the information will flow with the incorrect config, how the connections will now be made etc.
We changed the string name to match the service and the issue was resolved but it doesn't really make sense considering that the sole purpose of putting the string there is so that the loadbalancer will insert the name of that particular service in the cookie.
looking forward to hearing more from you then,
