Issues Changing Port to Switchport
Hello Experts,
When I paste the following config (see at end of discussion) I keep on getting the error message 'Command rejected: Not a switchable port'
interface Port-channel2
switchport
switchport mode trunk
no shutdown
Router(config)#interface Port-channel2
Router(config-if)# switchport
Command rejected: Not a switchable port.
Then when I enter configure the actual interface I get the following error:
Router(config-if)#int eth 1/1
Router(config-if)#interface Ethernet1/1
Router(config-if)# switchport trunk encapsulation dot1q
Router(config-if)# switchport mode trunk
Router(config-if)# duplex auto
Router(config-if)# channel-group 2 mode passive
Command rejected (Et1/1): Either port is L2 and port-channel is L3, or vice-versa
Now, this occurs only when I paste the entire config as follows:
hostname ALS1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode mst
spanning-tree pathcost method long
spanning-tree mst configuration
instance 1 vlan 100, 200
instance 2 vlan 300, 400
instance 3 vlan 500, 600
instance 4 vlan 700, 800
spanning-tree mst 3 priority 0
errdisable recovery cause channel-misconfig
errdisable recovery interval 600
vlan internal allocation policy ascending
switchport
no shutdown
interface Port-channel4
switchport
no shutdown
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface Ethernet0/1
no ip address
shutdown
duplex auto
interface Ethernet0/2
no ip address
shutdown
duplex auto
interface Ethernet0/3
no ip address
shutdown
duplex auto
interface Ethernet1/0
switchport
duplex auto
no shut
switchport
duplex auto
no shut
interface Ethernet1/2
switchport
duplex auto
channel-group 4 mode passive
no shut
interface Ethernet1/3
switchport
duplex auto
no shut
interface Ethernet2/0
no ip address
shutdown
duplex auto
interface Ethernet2/1
no ip address
shutdown
duplex auto
interface Ethernet2/2
no ip address
shutdown
duplex auto
interface Ethernet2/3
no ip address
shutdown
duplex auto
interface Ethernet3/0
no ip address
shutdown
duplex auto
interface Ethernet3/1
no ip address
shutdown
duplex auto
interface Ethernet3/2
no ip address
shutdown
duplex auto
interface Ethernet3/3
no ip address
shutdown
duplex auto
interface Vlan1
no ip address
shutdown
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
ALS1#
I should mention that the configs work fine when I built them from scratch. I only have problems when pasting the whole configs in one shot.
My guess is that switch doesn't like the port-channels to be pasted in before the actual configs for the actual interface - but thats just a wild guess.
Can you please shed some light on the situation?
Cheers
Carlton
My guess is :
Port Channel's are logical channels.. for it to work, the interface configuration has to be proper.
so can you try pasting all the configuration (except interface configuration pertaining to port channel)  then configure the interface configuration and then the port channel configuration. I hope that should work.
-Vijay
Hi Vijay,
As I pointed out at the end of my statement - I think the problem was because when pasting the whole configuration in one shot the the port-channels get pasted in first and I think the router doesn't like having the port-channel configs pasted before the actual configs of the actual interfaces.
So in a way, you agree with me.....
Yes. To me it makes sense.
since the port channel configuration depends on your interface configuration and when you paste the configuration , port channel appears first on the config. so the router might not undrestand what to do with it since it does not have the interface configuration yet so I guess it throws out that error message.
Just my 2 cents !!
-Vijay
