Issues with Router Cisco 2921 with EtherSwitch
Dear Folks
  I contact you due that I’m currently configuring a Router Cisco 2921 with an Etherswitch module.
  The specific inventory of Router Cisco 2921 is:
Router#show inventory
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V06 , SN: XXXXXXXXXXX
NAME: "High Speed WAN Interface Card - 1 Port Gigabit Ethernet on Slot 0 SubSlot 0", DESCR: "High Speed WAN Interface Card - 1 Port Gigabit Ethernet"
PID: HWIC-1GE-SFP      , VID: V01 , SN: XXXXXXXXXXX
NAME: "SM-ES3G-16-P: EtherSwitch SM L3 + PoE + 16 10/100/1000 on Slot 1", DESCR: "SM-ES3G-16-P: EtherSwitch SM L3 + PoE + 16 10/100/1000"
PID: SM-ES3G-16-P      , VID: V02 , SN: XXXXXXXXXXX
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V02 , SN: XXXXXXXXXXX
Router#
Router#show version
Compiled Tue 06-Dec-11 17:09 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M3.bin"
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1552AJAN
6 Gigabit Ethernet interfaces
2 terminal lines
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9        XXXXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Router#
Inside the EtherSwitch module:
EtherSwitch#show version
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(52)EX1, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(52r)EX, RELEASE SOFTWARE (fc1)
System image file is "flash:/c3560e-universalk9-mz.122-52.EX1.bin"
License Level: ipbase
License Type: Default. No valid license found.
Next reload license Level: ipbase
cisco SM-ES3G-16-P (PowerPC405) processor with 131072K bytes of memory.
Processor board ID FOC16454F6Y
Last reset from power-on
1 Virtual Ethernet interface
18 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : XX:XX:XX:XX:XX:XX
Motherboard serial number       : XXXXXXXXXXX
Model number                    : SM-ES3G-16-P
System serial number            : XXXXXXXXXXX
Hardware Board Revision Number  : 0x00
Switch Ports Model              SW Version            SW Image
*    1 18    SM-ES3G-16-P       12.2(52)EX1           C3560E-UNIVERSALK9-M
Configuration register is 0xF
EtherSwitch#
My current issue is when I tryied to config the following commands:
1. ISSUE inside Router config
Router(config)#class-map match-any virus-threat
Router(config-cmap)# match protocol http url "*.pst"
Router(config-cmap)# match protocol http url "*.reg"
% Exceeded maximum #(20) of subport instances
   I'm not able to add more http urls to the match protocl
2. ISSUE QoS Class-Map & Policy-Map inside EtherSwitch
   Inside the EtherSwitch Module i try to apply
EtherSwitch(config)#class-map match-all voip
EtherSwitch(config-cmap)# match protocol rtp
% Invalid input detected at '^' marker.
EtherSwitch(config-pmap)#
EtherSwitch(config)#policy-map QoS-Entel-out
EtherSwitch(config-pmap)# class voip
EtherSwitch(config-pmap)#  priority percent 8
3. ISSUE QoS outbound Policy inside EtherSwitch
   Inside the EtherSwitch Module i try to apply a QoS policy in an outbound interface direction
EtherSwitch(config-if)#service-policy output QoS-ISP-Out
Warning: Assigning a policy map to the output side of an interface not supported
Service Policy attachment failed
4. ISSUE NAT inside EtherSwitch
   NAT applied in an Etherswitch interface
EtherSwitch(config-if)# ip nat allow-static-host
   Any assistance is really appreciated in order to overcome this issues.
     Best regards
       Claudio
0 Replies 0
