Peer to Peer Blocking on cisco network
Srinivas N
Dear Friends,
I am working on wi-fi networks (ISP), So I need to block the peer to peer on my network.
My network involves cisco switch 2950/2960, cisco 2800 routers and Access Points,
Please help of config for peer to peer blocking, for this where I need to config either switches or router.
My network basic setup is, The internet will pass from router to switch and then Access Points.
Thanks & Regards,
Srinivas. N.
Thanks & Regards,
Srinivas.
Did you ever think of Privat VLANs?
http://www.cisco.com/en/US/tech/tk389/tk814/tk840/tsd_technology_support_sub-protocol_home.html
on the WLC if u use one u can make sure that the Wi-Fi clients can't use peer-to-peer connection. But as far as I see here the network is your problem. I have no idea in the moment only the P-VLANs could maybe help.
