Issues with tftp and running config backups.
lostsurfer
I just recently setup Solar Winds tftp and am using the following commands below to backup my running config to tftp. They do upload to the tftp but every day as a new config is written it's in a numbered seq. (ie-3900-switch backup 1, 3900-switch backup 2, 3900-switch backup 3, etc). I've checked all the settings on the tftp, and they all look correct. Is there something I'm missing??? I would like the daily backup to overwrite the previous one.
Thanks in advance!
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
path tftp://DEVICE-IP//DEVICE-HOST-NAME
time-period 1440
acampbell
Try adding
archive
maximum 1
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks for the response, tried it and got, "Cannot set maximum when backing up to network path"
as a workaround you coul use kron instead of the archive feature.
Here's an example
kron occurrence backup at 00:00 sun recurring
policy-list backup
kron policy-list backup
wr
show running-config | redirect tftp:///
Alain
