Issues with VRF and EIGRP
Kemal Zuko
Level 3
Level 3
Hi All,
We are testing a new design for our new Data Center refresh project. In my current LAB I have 1 Cisco  3750e Layer 3 switch, one ASA 5520.
The ASA and the Cisco 3750 connect on a stick. I am using transit VRF's to connect the two together. As my routing protocol I am using EIGRP to establish connection between the two. The reason I have VRF's on the L3 switch is because I want the switch to be the gateway for all workstations, and there are multiple zones so to say.
DMZ network - 172.16.0.0/23
Inside Netework - 172.16.2.0/23
F5 Front Porch- 172.16.12.0/23
F5 Back porch (hosts behind the F5) - 172.16.13.0/24
I have attached a little diagram as well
The idea #1 behind all this is to have the DMZ and the Inside Networks be able to get to one another by being inspected by the ASA. That works
The #2 is that all hosts behind the F5 can get to DMZ and Inside hosts the same way (being inspected by ASA) That is also working
and the #3 is that DMZ and Inside hoists can get to the hosts behind the F5. That is NOT working.
As far as the confioguration here is what I have currently
---- SWITCH ----
Switch1# sh run
Building configuration...
version 15.0
no service pad
hostname Switch1
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
ip vrf DMZ
 description DMZ Users
ip vrf F5_Front
 description Front-Porch-of-F5
ip vrf Inside
 description Inside users
no ip domain-lookup
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 no ip route-cache
interface GigabitEthernet1/0/1
 description To ASA
 switchport trunk allowed vlan 450-454
 switchport mode trunk
interface GigabitEthernet1/0/2
 description Uplink to F5
 switchport trunk allowed vlan 120,122
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
 description Uplink to Node-Behind-F5
 switchport access vlan 122
 switchport mode access
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/47
 switchport access vlan 162
 spanning-tree portfast
interface GigabitEthernet1/0/48
 switchport access vlan 160
interface Vlan1
 no ip address
interface Vlan120
 ip vrf forwarding F5_Front
 ip address 172.16.12.1 255.255.255.0
interface Vlan160
 ip vrf forwarding DMZ
 ip address 172.16.0.1 255.255.254.0
interface Vlan162
 description Inside
 ip vrf forwarding Inside
 ip address 172.16.2.1 255.255.254.0
interface Vlan450
 description VRF_DMZ_P2P
 ip address 172.16.250.1 255.255.255.248
interface Vlan451
 description VRF_Inside_P2P
 ip address 172.16.250.9 255.255.255.248
interface Vlan454
 description P2P_F5_Front
 ip address 172.16.250.33 255.255.255.248
router eigrp 99
 address-family ipv4 vrf DMZ autonomous-system 99
  network 172.16.0.0 0.0.1.255
  network 172.16.250.0 0.0.0.7
  passive-interface default
  no passive-interface Vlan450
  eigrp router-id 172.16.250.1
 exit-address-family
 address-family ipv4 vrf Inside autonomous-system 99
  network 172.16.2.0 0.0.1.255
  network 172.16.250.8 0.0.0.7
  no passive-interface Vlan451
  eigrp router-id 172.16.250.9
 exit-address-family
 address-family ipv4 vrf F5_Front autonomous-system 99
  redistribute static
  network 172.16.12.0 0.0.0.255
  network 172.16.13.0 0.0.0.255
  network 172.16.250.32 0.0.0.7
  no passive-interface Vlan454
  eigrp router-id 172.16.250.33
 exit-address-family
 network 172.16.0.0
 eigrp router-id 172.16.0.1
ip http server
ip http secure-server
ip route vrf F5_Front 172.16.13.0 255.255.255.0 172.16.12.3
line con 0
 logging synchronous
line vty 0 4
 login
line vty 5 15
 login
end
Switch1#
Switch1#sh ip route vrf DMZ
Routing Table: DMZ
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 8 subnets, 4 masks
C        172.16.0.0/23 is directly connected, Vlan160
L        172.16.0.1/32 is directly connected, Vlan160
D        172.16.2.0/23 [90/3328] via 172.16.250.2, 00:37:43, Vlan450
D        172.16.12.0/24 [90/3328] via 172.16.250.2, 00:37:42, Vlan450
C        172.16.250.0/29 is directly connected, Vlan450
L        172.16.250.1/32 is directly connected, Vlan450
D        172.16.250.8/29 [90/3072] via 172.16.250.2, 00:37:43, Vlan450
D        172.16.250.32/29 [90/3072] via 172.16.250.2, 00:37:43, Vlan450
Switch1#sh ip route vrf Inside
Routing Table: Inside
D        172.16.0.0/23 [90/3328] via 172.16.250.10, 00:37:49, Vlan451
C        172.16.2.0/23 is directly connected, Vlan162
L        172.16.2.1/32 is directly connected, Vlan162
D        172.16.12.0/24 [90/3328] via 172.16.250.10, 00:37:48, Vlan451
D        172.16.250.0/29 [90/3072] via 172.16.250.10, 00:37:49, Vlan451
C        172.16.250.8/29 is directly connected, Vlan451
L        172.16.250.9/32 is directly connected, Vlan451
D        172.16.250.32/29 [90/3072] via 172.16.250.10, 00:37:49, Vlan451
Switch1#sh ip route vrf F5_Front
Routing Table: F5_Front
      172.16.0.0/16 is variably subnetted, 9 subnets, 4 masks
D        172.16.0.0/23 [90/3328] via 172.16.250.34, 00:38:01, Vlan454
D        172.16.2.0/23 [90/3328] via 172.16.250.34, 00:38:01, Vlan454
C        172.16.12.0/24 is directly connected, Vlan120
L        172.16.12.1/32 is directly connected, Vlan120
S        172.16.13.0/24 [1/0] via 172.16.12.3
D        172.16.250.0/29 [90/3072] via 172.16.250.34, 00:38:01, Vlan454
D        172.16.250.8/29 [90/3072] via 172.16.250.34, 00:38:01, Vlan454
C        172.16.250.32/29 is directly connected, Vlan454
L        172.16.250.33/32 is directly connected, Vlan454
Switch1#
Switch1#sh ip eigrp vrf DMZ topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.1) VRF(DMZ)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 172.16.250.32/29, 1 successors, FD is 3072
        via 172.16.250.2 (3072/2816), Vlan450
P 172.16.250.0/29, 1 successors, FD is 2816
        via Connected, Vlan450
P 172.16.2.0/23, 1 successors, FD is 3328
        via 172.16.250.2 (3328/3072), Vlan450
P 172.16.250.8/29, 1 successors, FD is 3072
P 172.16.0.0/23, 1 successors, FD is 2816
        via Connected, Vlan160
P 172.16.12.0/24, 1 successors, FD is 3328
Switch1#sh ip eigrp vrf Inside topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.9) VRF(Inside)
        via 172.16.250.10 (3072/2816), Vlan451
P 172.16.250.0/29, 1 successors, FD is 3072
P 172.16.2.0/23, 1 successors, FD is 2816
        via Connected, Vlan162
P 172.16.250.8/29, 1 successors, FD is 2816
        via Connected, Vlan451
P 172.16.0.0/23, 1 successors, FD is 3328
        via 172.16.250.10 (3328/3072), Vlan451
Switch1#
Switch1#sh ip eigrp vrf F5_Front topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.33) VRF(F5_Front)
P 172.16.250.32/29, 1 successors, FD is 2816
        via Connected, Vlan454
        via 172.16.250.34 (3072/2816), Vlan454
        via 172.16.250.34 (3328/3072), Vlan454
P 172.16.12.0/24, 1 successors, FD is 2816
        via Connected, Vlan120
Switch1#
Switch1# sh ip eigrp vrf DMZ neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(DMZ)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.2            Vl450                    11 00:39:57    1   100  0  93
Switch1#
Switch1# sh ip eigrp vrf Inside neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(Inside)
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.10           Vl451                    12 00:40:22    1   100  0  92
Switch1#
Switch1# sh ip eigrp vrf F5_Front neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(F5_Front)
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.34           Vl454                    11 00:40:35    1   100  0  94
Switch1#
---- ASA ----
ciscoasa# sh run
: Saved
ASA Version 9.1(2)
hostname ciscoasa
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet0/0
 description N/A
 speed 1000
 duplex full
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/0.450
 description DMZ VRF Transit
 vlan 450
 nameif DMZ_P2P
 security-level 80
 ip address 172.16.250.2 255.255.255.248
interface GigabitEthernet0/0.451
 description Inside VRF Transit
 vlan 451
 nameif Inside_P2P
 security-level 100
 ip address 172.16.250.10 255.255.255.248
interface GigabitEthernet0/0.454
 vlan 454
 nameif F5_Front
 security-level 100
 ip address 172.16.250.34 255.255.255.248
interface GigabitEthernet0/1
 shutdown
 no nameif
 security-level 0
 no ip address
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/1
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/3
 nameif outside
 security-level 0
 ip address dhcp setroute
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network DMZ
 subnet 172.16.0.0 255.255.254.0
 description 255.255.254.0
object network Inside
 subnet 172.16.2.0 255.255.254.0
object network F5_Front
 subnet 172.16.12.0 255.255.255.0
 description Front Porch
object-group icmp-type DM_INLINE_ICMP_4
 icmp-object echo
 icmp-object echo-reply
 icmp-object time-exceeded
 icmp-object traceroute
access-list Inside_access_in extended permit tcp host 172.16.2.3 host 172.16.13.10 eq 3389
access-list Inside_access_in extended permit tcp host 172.16.2.3 host 172.16.0.3 eq 3389
access-list Inside_access_in extended permit ip any any
access-list DMZ_access_in extended permit tcp host 172.16.0.3 host 172.16.13.10 eq 3389
access-list DMZ_access_in extended permit ip any any
access-list F5_Front_access_in extended permit tcp host 172.16.13.10 host 172.16.0.3 eq 3389
access-list F5_Front_access_in extended permit ip any any
access-list P2P_Transient_F5_Behind_access_in extended permit icmp any any time-exceeded
access-list P2P_Transient_F5_Behind_access_in extended permit ip any any
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu DMZ_P2P 1500
mtu Inside_P2P 1500
mtu VPN_DMZ_P2P 1500
mtu DD_P2P 1500
mtu F5_Front 1500
mtu MGMT 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 10 burst-size 5
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (F5_Front,Inside_P2P) source static F5_Front F5_Front destination static F5_Front F5_Front
nat (F5_Front,DMZ_P2P) source static F5_Front F5_Front destination static F5_Front F5_Front
access-group DMZ_access_in in interface DMZ_P2P
access-group Inside_access_in in interface Inside_P2P
access-group F5_Front_access_in in interface F5_Front
router eigrp 99
 no auto-summary
 eigrp router-id 172.18.36.3
 network 172.16.250.0 255.255.255.248
 network 172.16.250.8 255.255.255.248
 network 172.16.250.32 255.255.255.248
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map Trace
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:181ea09181ebdcc95538aa0421ed7630
: end
ciscoasa#
ciscoasa# sh eigrp topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.18.36.3)
P 172.16.250.0 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.450
P 172.16.250.8 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.451
P 172.16.250.32 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.454
P 172.16.12.0 255.255.255.0, 1 successors, FD is 3072
        via 172.16.250.33 (3072/2816), GigabitEthernet0/0.454
P 172.16.0.0 255.255.254.0, 1 successors, FD is 3072
        via 172.16.250.1 (3072/2816), GigabitEthernet0/0.450
P 172.16.2.0 255.255.254.0, 1 successors, FD is 3072
        via 172.16.250.9 (3072/2816), GigabitEthernet0/0.451
ciscoasa#
ciscoasa# sh eigrp neighbors
EIGRP-IPv4 neighbors for process 99
                                            (sec)         (ms)       Cnt Num
2   172.16.250.33           Gi0/0.454        11  00:44:10 10   200   0   17
0   172.16.250.9            Gi0/0.451        14  00:44:11 13   200   0   22
1   172.16.250.1            Gi0/0.450        11  00:44:11 14   200   0   27
ciscoasa#
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
Gateway of last resort is 99.27.124.1 to network 0.0.0.0
C    1.1.1.0 255.255.252.0 is directly connected, outside
C    172.16.250.0 255.255.255.248 is directly connected, DMZ_P2P
C    172.16.250.8 255.255.255.248 is directly connected, Inside_P2P
C    172.16.250.16 255.255.255.248 is directly connected, VPN_DMZ_P2P
C    172.16.250.24 255.255.255.248 is directly connected, DD_P2P
C    172.16.250.32 255.255.255.248 is directly connected, F5_Front
D    172.16.12.0 255.255.255.0 [90/3072] via 172.16.250.33, 0:44:15, F5_Front
D    172.16.0.0 255.255.254.0 [90/3072] via 172.16.250.1, 0:44:16, DMZ_P2P
D    172.16.2.0 255.255.254.0 [90/3072] via 172.16.250.9, 0:44:16, Inside_P2P
C    172.18.36.0 255.255.255.0 is directly connected, MGMT
S    172.22.36.0 255.255.255.0 [1/0] via 172.18.36.1, MGMT
d*   0.0.0.0 0.0.0.0 [1/0] via 1.1.1.1, outside
ciscoasa#
----------- END ---------
When I do a traceroute from DMZ network (workstation 172.16.0.3) to Host behind the F5 172.16.13.10 my traceroute dies at the gateway of the Workstation 172.16.0.1.
I have never attempted this VRF design with EIGRP and a device that is not supporting EIGRP in my case the F5 load balancer.
All traffic from DMZ and Inside network should be forced to 172.16.12.3 which is the F5 Front side. From there the F5 knows hot to handle that traffic.
My packets are not getting out of the gateway so it never reaches the Front of the F5.
What am I missing here? Is this even possible?
Thanks in Advance
Just found an article that confirms you need a metric with EIGRP when you redistribute static within a VRF so I think that is your problem.
Jon
21 Replies 21
Jon Marshall
It's quite a complicated setup so I may have missed something but are you sure about the above.
The inside, DMZ VRFs and the ASA have no knowledge of the 172.16.13.0/24 subnet so I can't see how the above is working.
The fact you can't traceroute from an inside or DMZ client to those hosts makes sense because there are no routes for that subnet in their VRF routing tables.
The only VRF that does know about that subnet is the F5_Front VRF.
Like I say I may have missed something but I can't see how 2 or 3 would work without routes.
Jon
Hi Jon,
The #2 is working I just double checked. The host behind the F5 172.16.13.10 can RDP to ether DMZ 172.16.0.3 and Inside 172.16.2.3. When I block RDP access on the ASA the session drops. The reason that host behind the F5 can get there is because of the default route on the F5 that reads the following
0.0.0.0 0.0.0.0 172.16.12.1
So any traffic going out use the 172.16.12.1 gateway on the switch. In that case that is the F5_Front VRF.
And correct the other way around does not work because there are no routes, I am trying to figure out how to make this work full circle.
I don't think it's that simple.
Your 172.16.13.x hosts may have a route on the F5 to get out to the switch but when the traffic returns the destination IP is 172.16.13.x and so an inside or DMZ host couldn't route that traffic back because there are no routes.
So I don't think 2 is working as you expect.
Jon
What would be a better test?
When I run wire shark I can see the 3 way TCP handshake being completed. I am testing only RDP session and some ICMP ping tests.
Well I am only saying I can't see how it works as you still need routes back to the 172.16.13.x subnet and we know they aren't there.
So I can't see how this is working unless you are doing NAT on the 172.16.13.x IPs to something else eg,, the 172.16.12.x F5 front door IPs in which case the return path would work.
Are you sure your F5 is not simply translating them to 172.16.12.x IPs ?
Where are you running the packet capture ?
If it is on the 172.16.13.x host you won't see that.
You would need to run it on the inside or DMZ host to see what IP it is.
Jon
Joh,
You are right.
There is a SNAT that is 172.16.12.10 that my DMZ hosts sees. It does not see the 13.x network.
If I remove the sNAT it does not work.
Any ideas where I need more routes?
Good, because otherwise I would have had no idea what was going on 🙂
You could add routes to the inside and DMZ VRFs but perhaps a simpler solution is to add a static route on the firewall for the 172.16.13.0/24 subnet with a next hop of the SVI IP address for vlan 454 on the switch.
Then redistribute this into EIGRP so the inside and DMZ VRFs receive the route.
All you are trying to do is get traffic to flow via the ASA so that may be the best place to do it.
Jon
Joh,
Here is the command output
ciscoasa# sh eigrp topology all-links
P 172.16.250.0 255.255.255.248, 1 successors, FD is 2816, serno 1
P 172.16.250.8 255.255.255.248, 1 successors, FD is 2816, serno 2
P 172.16.250.32 255.255.255.248, 1 successors, FD is 2816, serno 3
P 172.16.12.0 255.255.255.0, 1 successors, FD is 3072, serno 20
P 172.16.0.0 255.255.254.0, 1 successors, FD is 3072, serno 16
P 172.16.2.0 255.255.254.0, 1 successors, FD is 3072, serno 18
ciscoasa1#
and here is when I try to create a route for DMZ on the firewall
ciscoasa(config)# route DMZ_P2P 172.16.13.0 255.255.255.0 172.16.250.34
%Invalid next hop address, it belongs to one of our interfaces
The next hop would be 172.16.250.33 ie. the SVI on the switch.
But you shouldn't need to add that route because you are redistributing the static in your F5_Front VRF so that should get to the ASA.
I don't have anything to test with at the moment but before you add any routes to the ASA can you try -
1) under your EIGRP address family configuration on the switch for the F5_Front VRF remove the "network 172.16.13.0 0.0.0.255" statement as it is not doing anything
if that makes no difference and I suspect it won't then -
2) can you try adding a metric to the "redistribute static" statement. You shouldn't need a metric for statics but I'm wondering if because it is an address family that makes a difference.
Ideally you want that route to be sent to the ASA then all the routing is in place rather than having to add more routes to other devices.
In addition you may need some more NAT statements covering the 172.16.13.0/24 subnet on your ASA although you may not.
Sorry to be vague but I am still getting up to speed with post 8.3 NAT on ASAs 🙂
Lets try and get the routing working first though.
Jon
Jon
Actually I just realised you are redistributing that static route for 172.16.13.0/24 in the F5_Front VRF so your ASA should receive that but it isn't.
Not sure why at present.
Can you post a "sh ip eigrp topology all-links" from the ASA (assuming that command works on the firewall).
Jon
Joh,
You are right.
Kemal Zuko
Level 3
Level 3
Joh,
I Agree,
Ok here is what I got so far
router eigrp 99
 exit-address-family
 exit-address-family
  redistribute static metric 56 100 255 1 1500
 exit-address-family
 network 172.16.0.0
ip http server
and by adding those metrics everything is working without the sNAT's and with the sNAT's
I did have the following implemented for a while
access-list 10 permit 172.16.13.0 0.0.0.255 log
route-map STATIC permit 10
 match ip address 10
 set metric 56 100 255 1 1500
 set tag 2
 address-family ipv4 vrf F5_Front autonomous-system 1
  redistribute static route-map STATIC
That did not work well, although it was using the same metrics, that is where I gathered my existing metrics.
However I would like to Thank you for your time and help on this issue.
Kemal
Kemal
No problem, glad you got it working.
Jon
