Issues with VRF and EIGRP
Kemal Zuko
Hi All,
We are testing a new design for our new Data Center refresh project. In my current LAB I have 1 Cisco  3750e Layer 3 switch, one ASA 5520.
The ASA and the Cisco 3750 connect on a stick. I am using transit VRF's to connect the two together. As my routing protocol I am using EIGRP to establish connection between the two. The reason I have VRF's on the L3 switch is because I want the switch to be the gateway for all workstations, and there are multiple zones so to say.
DMZ network - 172.16.0.0/23
Inside Netework - 172.16.2.0/23
F5 Front Porch- 172.16.12.0/23
F5 Back porch (hosts behind the F5) - 172.16.13.0/24
I have attached a little diagram as well
The idea #1 behind all this is to have the DMZ and the Inside Networks be able to get to one another by being inspected by the ASA. That works
The #2 is that all hosts behind the F5 can get to DMZ and Inside hosts the same way (being inspected by ASA) That is also working
and the #3 is that DMZ and Inside hoists can get to the hosts behind the F5. That is NOT working.
As far as the confioguration here is what I have currently
---- SWITCH ----
Switch1# sh run
Building configuration...
version 15.0
no service pad
hostname Switch1
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
ip vrf DMZ
 description DMZ Users
ip vrf F5_Front
 description Front-Porch-of-F5
ip vrf Inside
 description Inside users
no ip domain-lookup
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 no ip route-cache
interface GigabitEthernet1/0/1
 description To ASA
 switchport trunk allowed vlan 450-454
 switchport mode trunk
interface GigabitEthernet1/0/2
 description Uplink to F5
 switchport trunk allowed vlan 120,122
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
 description Uplink to Node-Behind-F5
 switchport access vlan 122
 switchport mode access
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/47
 switchport access vlan 162
 spanning-tree portfast
interface GigabitEthernet1/0/48
 switchport access vlan 160
interface Vlan1
 no ip address
interface Vlan120
 ip vrf forwarding F5_Front
 ip address 172.16.12.1 255.255.255.0
interface Vlan160
 ip vrf forwarding DMZ
 ip address 172.16.0.1 255.255.254.0
interface Vlan162
 description Inside
 ip vrf forwarding Inside
 ip address 172.16.2.1 255.255.254.0
interface Vlan450
 description VRF_DMZ_P2P
 ip address 172.16.250.1 255.255.255.248
interface Vlan451
 description VRF_Inside_P2P
 ip address 172.16.250.9 255.255.255.248
interface Vlan454
 description P2P_F5_Front
 ip address 172.16.250.33 255.255.255.248
router eigrp 99
 address-family ipv4 vrf DMZ autonomous-system 99
  network 172.16.0.0 0.0.1.255
  network 172.16.250.0 0.0.0.7
  passive-interface default
  no passive-interface Vlan450
  eigrp router-id 172.16.250.1
 exit-address-family
 address-family ipv4 vrf Inside autonomous-system 99
  network 172.16.2.0 0.0.1.255
  network 172.16.250.8 0.0.0.7
  no passive-interface Vlan451
  eigrp router-id 172.16.250.9
 exit-address-family
 address-family ipv4 vrf F5_Front autonomous-system 99
  redistribute static
  network 172.16.12.0 0.0.0.255
  network 172.16.13.0 0.0.0.255
  network 172.16.250.32 0.0.0.7
  no passive-interface Vlan454
  eigrp router-id 172.16.250.33
 exit-address-family
 network 172.16.0.0
 eigrp router-id 172.16.0.1
ip http server
ip http secure-server
ip route vrf F5_Front 172.16.13.0 255.255.255.0 172.16.12.3
line con 0
 logging synchronous
line vty 0 4
 login
line vty 5 15
 login
end
Switch1#
Switch1#sh ip route vrf DMZ
Routing Table: DMZ
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 8 subnets, 4 masks
C        172.16.0.0/23 is directly connected, Vlan160
L        172.16.0.1/32 is directly connected, Vlan160
D        172.16.2.0/23 [90/3328] via 172.16.250.2, 00:37:43, Vlan450
D        172.16.12.0/24 [90/3328] via 172.16.250.2, 00:37:42, Vlan450
C        172.16.250.0/29 is directly connected, Vlan450
L        172.16.250.1/32 is directly connected, Vlan450
D        172.16.250.8/29 [90/3072] via 172.16.250.2, 00:37:43, Vlan450
D        172.16.250.32/29 [90/3072] via 172.16.250.2, 00:37:43, Vlan450
Switch1#sh ip route vrf Inside
Routing Table: Inside
D        172.16.0.0/23 [90/3328] via 172.16.250.10, 00:37:49, Vlan451
C        172.16.2.0/23 is directly connected, Vlan162
L        172.16.2.1/32 is directly connected, Vlan162
D        172.16.12.0/24 [90/3328] via 172.16.250.10, 00:37:48, Vlan451
D        172.16.250.0/29 [90/3072] via 172.16.250.10, 00:37:49, Vlan451
C        172.16.250.8/29 is directly connected, Vlan451
L        172.16.250.9/32 is directly connected, Vlan451
D        172.16.250.32/29 [90/3072] via 172.16.250.10, 00:37:49, Vlan451
Switch1#sh ip route vrf F5_Front
Routing Table: F5_Front
      172.16.0.0/16 is variably subnetted, 9 subnets, 4 masks
D        172.16.0.0/23 [90/3328] via 172.16.250.34, 00:38:01, Vlan454
D        172.16.2.0/23 [90/3328] via 172.16.250.34, 00:38:01, Vlan454
C        172.16.12.0/24 is directly connected, Vlan120
L        172.16.12.1/32 is directly connected, Vlan120
S        172.16.13.0/24 [1/0] via 172.16.12.3
D        172.16.250.0/29 [90/3072] via 172.16.250.34, 00:38:01, Vlan454
D        172.16.250.8/29 [90/3072] via 172.16.250.34, 00:38:01, Vlan454
C        172.16.250.32/29 is directly connected, Vlan454
L        172.16.250.33/32 is directly connected, Vlan454
Switch1#
Switch1#sh ip eigrp vrf DMZ topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.1) VRF(DMZ)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 172.16.250.32/29, 1 successors, FD is 3072
        via 172.16.250.2 (3072/2816), Vlan450
P 172.16.250.0/29, 1 successors, FD is 2816
        via Connected, Vlan450
P 172.16.2.0/23, 1 successors, FD is 3328
        via 172.16.250.2 (3328/3072), Vlan450
P 172.16.250.8/29, 1 successors, FD is 3072
P 172.16.0.0/23, 1 successors, FD is 2816
        via Connected, Vlan160
P 172.16.12.0/24, 1 successors, FD is 3328
Switch1#sh ip eigrp vrf Inside topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.9) VRF(Inside)
        via 172.16.250.10 (3072/2816), Vlan451
P 172.16.250.0/29, 1 successors, FD is 3072
P 172.16.2.0/23, 1 successors, FD is 2816
        via Connected, Vlan162
P 172.16.250.8/29, 1 successors, FD is 2816
        via Connected, Vlan451
P 172.16.0.0/23, 1 successors, FD is 3328
        via 172.16.250.10 (3328/3072), Vlan451
Switch1#
Switch1#sh ip eigrp vrf F5_Front topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.16.250.33) VRF(F5_Front)
P 172.16.250.32/29, 1 successors, FD is 2816
        via Connected, Vlan454
        via 172.16.250.34 (3072/2816), Vlan454
        via 172.16.250.34 (3328/3072), Vlan454
P 172.16.12.0/24, 1 successors, FD is 2816
        via Connected, Vlan120
Switch1#
Switch1# sh ip eigrp vrf DMZ neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(DMZ)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.2            Vl450                    11 00:39:57    1   100  0  93
Switch1#
Switch1# sh ip eigrp vrf Inside neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(Inside)
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.10           Vl451                    12 00:40:22    1   100  0  92
Switch1#
Switch1# sh ip eigrp vrf F5_Front neighbors
EIGRP-IPv4 Neighbors for AS(99) VRF(F5_Front)
                                                   (sec)         (ms)       Cnt Num
0   172.16.250.34           Vl454                    11 00:40:35    1   100  0  94
Switch1#
---- ASA ----
ciscoasa# sh run
: Saved
ASA Version 9.1(2)
hostname ciscoasa
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet0/0
 description N/A
 speed 1000
 duplex full
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/0.450
 description DMZ VRF Transit
 vlan 450
 nameif DMZ_P2P
 security-level 80
 ip address 172.16.250.2 255.255.255.248
interface GigabitEthernet0/0.451
 description Inside VRF Transit
 vlan 451
 nameif Inside_P2P
 security-level 100
 ip address 172.16.250.10 255.255.255.248
interface GigabitEthernet0/0.454
 vlan 454
 nameif F5_Front
 security-level 100
 ip address 172.16.250.34 255.255.255.248
interface GigabitEthernet0/1
 shutdown
 no nameif
 security-level 0
 no ip address
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/1
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/3
 nameif outside
 security-level 0
 ip address dhcp setroute
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network DMZ
 subnet 172.16.0.0 255.255.254.0
 description 255.255.254.0
object network Inside
 subnet 172.16.2.0 255.255.254.0
object network F5_Front
 subnet 172.16.12.0 255.255.255.0
 description Front Porch
object-group icmp-type DM_INLINE_ICMP_4
 icmp-object echo
 icmp-object echo-reply
 icmp-object time-exceeded
 icmp-object traceroute
access-list Inside_access_in extended permit tcp host 172.16.2.3 host 172.16.13.10 eq 3389
access-list Inside_access_in extended permit tcp host 172.16.2.3 host 172.16.0.3 eq 3389
access-list Inside_access_in extended permit ip any any
access-list DMZ_access_in extended permit tcp host 172.16.0.3 host 172.16.13.10 eq 3389
access-list DMZ_access_in extended permit ip any any
access-list F5_Front_access_in extended permit tcp host 172.16.13.10 host 172.16.0.3 eq 3389
access-list F5_Front_access_in extended permit ip any any
access-list P2P_Transient_F5_Behind_access_in extended permit icmp any any time-exceeded
access-list P2P_Transient_F5_Behind_access_in extended permit ip any any
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu DMZ_P2P 1500
mtu Inside_P2P 1500
mtu VPN_DMZ_P2P 1500
mtu DD_P2P 1500
mtu F5_Front 1500
mtu MGMT 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 10 burst-size 5
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (F5_Front,Inside_P2P) source static F5_Front F5_Front destination static F5_Front F5_Front
nat (F5_Front,DMZ_P2P) source static F5_Front F5_Front destination static F5_Front F5_Front
access-group DMZ_access_in in interface DMZ_P2P
access-group Inside_access_in in interface Inside_P2P
access-group F5_Front_access_in in interface F5_Front
router eigrp 99
 no auto-summary
 eigrp router-id 172.18.36.3
 network 172.16.250.0 255.255.255.248
 network 172.16.250.8 255.255.255.248
 network 172.16.250.32 255.255.255.248
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map Trace
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:181ea09181ebdcc95538aa0421ed7630
: end
ciscoasa#
ciscoasa# sh eigrp topology
EIGRP-IPv4 Topology Table for AS(99)/ID(172.18.36.3)
P 172.16.250.0 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.450
P 172.16.250.8 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.451
P 172.16.250.32 255.255.255.248, 1 successors, FD is 2816
        via Connected, GigabitEthernet0/0.454
P 172.16.12.0 255.255.255.0, 1 successors, FD is 3072
        via 172.16.250.33 (3072/2816), GigabitEthernet0/0.454
P 172.16.0.0 255.255.254.0, 1 successors, FD is 3072
        via 172.16.250.1 (3072/2816), GigabitEthernet0/0.450
P 172.16.2.0 255.255.254.0, 1 successors, FD is 3072
        via 172.16.250.9 (3072/2816), GigabitEthernet0/0.451
ciscoasa#
ciscoasa# sh eigrp neighbors
EIGRP-IPv4 neighbors for process 99
                                            (sec)         (ms)       Cnt Num
2   172.16.250.33           Gi0/0.454        11  00:44:10 10   200   0   17
0   172.16.250.9            Gi0/0.451        14  00:44:11 13   200   0   22
1   172.16.250.1            Gi0/0.450        11  00:44:11 14   200   0   27
ciscoasa#
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
Gateway of last resort is 99.27.124.1 to network 0.0.0.0
C    1.1.1.0 255.255.252.0 is directly connected, outside
C    172.16.250.0 255.255.255.248 is directly connected, DMZ_P2P
C    172.16.250.8 255.255.255.248 is directly connected, Inside_P2P
C    172.16.250.16 255.255.255.248 is directly connected, VPN_DMZ_P2P
C    172.16.250.24 255.255.255.248 is directly connected, DD_P2P
C    172.16.250.32 255.255.255.248 is directly connected, F5_Front
D    172.16.12.0 255.255.255.0 [90/3072] via 172.16.250.33, 0:44:15, F5_Front
D    172.16.0.0 255.255.254.0 [90/3072] via 172.16.250.1, 0:44:16, DMZ_P2P
D    172.16.2.0 255.255.254.0 [90/3072] via 172.16.250.9, 0:44:16, Inside_P2P
C    172.18.36.0 255.255.255.0 is directly connected, MGMT
S    172.22.36.0 255.255.255.0 [1/0] via 172.18.36.1, MGMT
d*   0.0.0.0 0.0.0.0 [1/0] via 1.1.1.1, outside
ciscoasa#
----------- END ---------
When I do a traceroute from DMZ network (workstation 172.16.0.3) to Host behind the F5 172.16.13.10 my traceroute dies at the gateway of the Workstation 172.16.0.1.
I have never attempted this VRF design with EIGRP and a device that is not supporting EIGRP in my case the F5 load balancer.
All traffic from DMZ and Inside network should be forced to 172.16.12.3 which is the F5 Front side. From there the F5 knows hot to handle that traffic.
My packets are not getting out of the gateway so it never reaches the Front of the F5.
What am I missing here? Is this even possible?
Thanks in Advance
21 Replies 21
Kemal
Just out of interest when you say it did not work well what happened and are you seeing the same symptoms now ?
I only ask as you have used a bandwidth of 56 in your metric which is very low considering everything is gigabit within your LAN.
Even though you have used subinterfaces on the ASA that is still low.
Jon
Jon,
When I said it didn't work I was referring the to the following config:
access-list 10 permit 172.16.13.0 0.0.0.255 log
route-map STATIC permit 10
 match ip address 10
 set metric 56 100 255 1 1500
 set tag 2
 address-family ipv4 vrf F5_Front autonomous-system 1
  redistribute static route-map STATIC
The symptoms I was seeing were same, I was not able to get behind the F5 from DMZ or Inside. I did made some changes now that I think about it to the F5 and the Routing on the switch. I wonder if it would work now...
I agree the metric on that should be way higher 1000
Ahh okay, thanks for clarifying that.
Jon
Kemal
Sorry to keep posting and please feel free to ignore the suggestion but would it not simplify your configuration without the P2P VRFs ie. why can't you just not have SVIs on the 3750 for these vlans and simply use the ASA subinterfaces as the routed interfaces.
You would only need SVIs on he 3750 if you had multiple vlans in the same VRFs but you don't.
Well you do but only because of the P2P VRFs which aren't really needed.
You also wouldn't then need EIGRP at all because everything would be directly connected on the ASA except the 172.16.13.0/24 subnet which you would still need a static route for on the ASA.
You may have a reason so please feel free to ignore.
Jon
Jon,
Thanks for the suggestion. This is just a LAB to see if this will work with our new equipment.
The main reason for VRF's is that we would like the new Nexus 6K's to be our core routers/switches the gateway for different sub-nets. We will also run vPC and HSRP between the new N6K's.
The purpose for VRF Transit vlan's is (aside being best practice) is to avoid unnecessary packets to touch ASA. Also to accommodate multiple VLAN under the same vrf to allow internal VLAN routing.
Does that make sense or am I over-complicating the design?
Kemal
If you intend to have multiple vlans using the same VRF on the Nexus switches then no your aren't overcomplicating it at all.
It was simply from your lab you only really had one vlan per VRF (apart from the P2P VRFs obviously) which is why I couldn't see what you were gaining from the way you had it and having to run EIGRP.
But yes from your description of what you are going to have in production your design makes perfect sense.
Jon
Hi Jon,
Good to hear that I am not over-complicating this :)
Thank you again for your help
Kemal
