I have a Cisco 3850 switch & trying to manually copy the running config using FTP protocol to the FTP server. The connectivity is actually through a VRF & Its having only one interface assigned to it.
When i do a telnet <server-IP> 21 Vrf <vrf-name> , the FTP server is accessible but when i do a telnet to the server with source interface as the "interface in VRF" , its failing.
Due to which i am unable to copy files manually through below command.
copy running-config ftp://username:pasword@<FTP server path> <source interface>
-AJ
