Jumbo Frames not in effect on Nexus 5548
mmedwid
Level 3
Level 3
According to this Cisco URL jumbo frames should be put into play by changing default ethernet system class.
Recommended configuration:
!--- You can enable the Jumbo MTU
!--- for the whole switch by setting the MTU
!--- to its maximum size (9216 bytes) in
!--- the policy map for the default
!--- Ethernet system class (class-default).switch(config)#policy-map type network-qos jumboswitch(config-pmap-nq)#class type network-qos class-defaultswitch(config-pmap-c-nq)#mtu 9216switch(config-pmap-c-nq)#exitswitch(config-pmap-nq)#exitswitch(config)#system qosswitch(config-sys-qos)#service-policy type network-qos jumbo
URL:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b44116.shtml
My configuration:
    mtu 9216
    multicast-optimize
system qos
One of my 10Gig interfaces showing only a 1500 MTU
Ethernet1/3 is up
  Hardware: 1000/10000 Ethernet, address: 547f.ee5c.69ca (bia 547f.ee5c.69ca)
  Description: Netapp FilerA e3a
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
Oleksandr Nesterov
Here is a link for video how to configure Jumbo frames:
https://supportforums.cisco.com/videos/1215
Also check "sh queuing interface eth 1/3"
there you will be able to see real mtu, since in some nx-os releases has a cosmetic issue in displaying correct mtu.
HTH,
Alex
vmiller
Level 7
Level 7
Something else to look for:
sh interface ether1/3
Ethernet1/3 is down (SFP not inserted)
  Hardware: 1000/10000 Ethernet, address: 000d.ecec.c9ca (bia 000d.ecec.c9ca)
  Description: ovhesx01_clstr01
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  Last link flapped never
  1 minute input rate 0 bits/sec, 0 packets/sec
  1 minute output rate 0 bits/sec, 0 packets/sec
  Rx
    0 input packets 0 unicast packets 0 multicast packets
    0 broadcast packets 0 jumbo packets 0 storm suppression packets
    0 bytes
  Tx
    0 output packets 0 multicast packets
    0 bytes
    0 input error 0 short frame 0 watchdog
    0 no buffer 0 runt 0 CRC 0 ecc
    0 overrun  0 underrun 0 ignored 0 bad etype drop
    0 bad proto drop 0 if down drop 0 input with dribble
    0 input discard
    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
    0 Rx pause 0 Tx pause
  0 interface resets
look for the jumbo frame counter.
