Karen
kyessayan11
Community Member
Hi all,
I have a problem with cisco 6509 sup-2ge engine. When i'm trying to boot an IOS image from the bootflash device i received this error
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Cat6k-MSFC2 platform with 131072 Kbytes of main memory
Could anybody help?
Thanks!
6 Replies 6
Reza Sharifi
Hi Karen,
Is the config register 0x2102?
Can you post "sh ver"?
Reza
aljaloudi
Level 2
Level 2
Hi Karen, This is because of NVRAM corruption/exception at rommon.
please contact Cisco TAC for RMA
To recover from Rommon,
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
Thanks for the link Osamah,
I've followed the steps in the document, but again there is a problem. When i'm trying to download the boot loader from slot0: to bootflash: there is a message
%Download failed
I don't know what is the reason.
aljaloudi
Level 2
Level 2
Hi Karen, please provide us with the output of "rommon 1 >dir bootflash:" and "Rommon 2 >set "
any hardware/software changes before the issue?
Before the problem I've tryed to make boot loader upgrade to make 64Mb flash card readable.Now there is a boot loader on the RP bootflash, and nothing on the SP bootflash. I want to know how can i copy the ios c6sup22 from my computer to the SP bootflash? The outputs are
System Bootstrap, Version 7.1(1)
Copyright (c) 1994-2001 by cisco Systems, Inc.
c6k_sup2 processor with 131072 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
boot: cannot determine first file name on device "bootflash:"
Exit at the end of BOOT string
rommon 1 > dir bootflash:
         File size           Checksum   File name
rommon 2 > dir slot0:
   6238236 bytes (0x5f301c)   0xc3d90a08    cat6000-sup2k8.7-4-3.bin
   1673992 bytes (0x198b08)   0x997d2076    c6msfc2-boot-mz.121-7.E
rommon 3 >boot slot0:cat6000-sup2k8.7-4-3.bin
Console> (enable) show version
WS-C6509 Software, Version NmpSW: 7.4(3)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Nov 27 2002, 18:27:42
System Bootstrap Version: 7.1(1)
Hardware Version: 3.0  Model: WS-C6509  Serial #: TBA05392260
PS2  Module: WS-CAC-1300W    Serial #: SNI05110357
Mod Port Model               Serial #    Versions
1   2    WS-X6K-SUP2-2GE     SAD053803VS Hw : 3.2
                                         Fw : 7.1(1)
                                         Fw1: 6.1(3)
                                         Sw : 7.4(3)
                                         Sw1: 7.4(3)
         WS-F6K-PFC2         SAD053802BA Hw : 2.0
3   16   WS-X6416-GBIC       SAL0537BMR6 Hw : 1.0
                                         Fw : 5.4(2)
                                         Sw : 7.4(3)
5   48   WS-X6148-RJ45V      SAL082802KR Hw : 3.1
                                         Fw : 5.4(2)
                                         Sw : 7.4(3)
                                         Hw : 2.0
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1      131072K  59038K  72034K  32768K   1537K  31231K  512K  257K  255K
Uptime is 0 day, 0 hour, 1 minute
Console> (enable)
Console> (enable) swi console
Trying Router-15...
Connected to Router-15.
Type ^C^C^C to switch back...
   1734148 bytes (0x1a7604)   0x8d01e5b1    c6msfc2-boot-mz.121-11b.E4.bin
  10178832 bytes (0x9b5110)   0x8f01f314    c6msfc2-psv-mz.121-7a.E1
rommon 2>boot bootflash:c6msfc2-boot-mz.121-11b.E4.bin
Router(boot)#show version
IOS (tm) MSFC2 Software (C6MSFC2-BOOT-M), Version 12.1(11b)E4, EARLY DEPLOYMENT
RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 30-May-02 18:43 by hqluong
Image text-base: 0x40008980, data-base: 0x40404000
ROM: System Bootstrap, Version 12.1(3r)E2, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2 Software (C6MSFC2-BOOT-M), Version 12.1(11b)E4, EARLY DEPLOYMENT
Router uptime is 6 minutes
System image file is "bootflash:c6msfc2-boot-mz.121-11b.E4.bin"
cisco Cat6k-MSFC2 (R7000) processor with 114688K/16384K bytes of memory.
Processor board ID SAD053801A9
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
509K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x100
Router(boot)#sho running-config
Building configuration...
Current configuration : 217 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
no ip http server
line con 0
line vty 0 4
end
When i'm booting the c6msfc2-boot-mz.121-11b.E4.bin image i can't see the modules. I cant configure an IP address on the interface to use tftp to download c6sup22 image on a bootflash:
Thanks!
