key-based authentication from Cisco IOS device
bbiggie
Community Member
Hopefully the title says it all - is there a way of using the ssh client to use a particular private key for ssh authentication?
The scenario I'm thinking of is to use the archive command to backup configs without having to use an scp url ( ie scp://user:password@servername/filename ).
Thanks in advance.
Ben
Mark Elsen
https://supportforums.cisco.com/document/110946/ssh-using-public-key-authentication-ios-and-big-outputs
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for the suggestion. I thought I'd been over that document quite thoroughly, but it all seemed to concern ssh connections towards an IOS ssh server - or am I missing something?
Ben
 - Not as the title of the document suggests , but I guess it needs to be tested.
M.
