Kron scheduler not working correctly
HunkIT
Hello Cisco Users
I have a problem with scheduling a tftp backup job with kron.
I confiured one of our C2960X with IOS 15.2(2)E3 switches like this:
kron policy-list ConfigBackup
cli copy running-config tftp://servername/switchbackup.cfg
kron occurrence ConfigBackup at 20:00 recurring
The problem is, if i set the scheduler to run the job about 5 or 10 minutes from now,
it works fine. But if i set the scheduler to run the job in about 4 hours (more then just a few minutes), it does not run the job at the scheduled time.
Does someone have the same issues?
Is there a solution for this problem?
Daniel
Hello
Since i added the line "cli write" to the command, it seems to work.
cli write
I will check tomorrow and will let you know if it works correctly now.
Thanks for your help!
Daniel
12 Replies 12
Daniel,
do you have:
2960X(config-kron-policy)# cli write
configured under your policy ?
After the policy has run, is it still visible with:
show kron schedule
Hi Georg
No, i dont. You mean it should look like this?
I will try this.
cli write
Yes, it is still visible after running:
ConfigBackup inactive, will run again in 0 days 00:23:41 at 9 :30 on
Daniel
you can also replace the cli line with a show run | redirect:
cli show run | redirect tftp://servername/switchbackup.cfg
Hello Daniel,
as an alternative, you could also run a simple EEM script:
event manager applet ConfigBackup
event timer cron cron-entry "0 20 * * *" maxrun 9999999
action 1.0 cli command "enable"
action 2.0 cli command "copy running-config tftp://servername/switchbackup.cfg"
sorry for the misunderstanding. The problem is that KRON does not support interactive commands that require user confirmation. Try replacing the line in bold with 'cli write' and see if that works. Also, in global config mode, configure:
2960X(config)#file prompt quiet
Hello
cli write
Daniel
motiar
Hi Daniel,
I have exactly the same problem, but only to some Switches. I configured for 40 Switches, 34 of them are working fine and 6 Switches have this problem. I also noticed that the policy-list will also remove from the Switch config and at the scheduled time and only the last two commands "kron occurrence ConfigBackup at 20:00 recurring, policy-list ConfigBackup" will remain.
How did you solve the problem?
Motiar
Hi Motiar
I use the following commands:
Enable Auto Backup:
    conf t
    cli write
    cli copy running-config tftp://your_ftp_server/switch01.cfg
    exit
    kron occurrence ConfigBackup at 18:00 recurring
    exit
    exit
    wr
Remove Auto Backup:
    conf t
    no kron policy-list ConfigBackup
    no kron occurrence ConfigBackup at 18:00 recurring
    exit
    wr
Change the Backup Time:
    conf t
    exit
    exit
    wr
Show Backup Plan:
    sh kron schedule
This works with all our Switches WS-C2960X-48LPD-L / WS-C4500X-16
Hope this helps.
Daniel
Guten Morgen Daniel,
Thank you for your details guidelines and indeed, it does work for my rest of the switches!! Actually ca. 40 Switche work perfectly with my following redirect commands with file format. And the 6 Switche work only with your suggested config (at the bottom) with .cfg format, even without cli write command. I don't know why.
conf t
kron policy-list BackupConfig
cli show run | redirect tftp://TFTP-Server/Switch01
exit
kron occurrence BackupConfig at 22:00 recurring
conf t
cli copy running-config tftp://TFTP-Server/Switch10.cfg
exit
kron occurrence BackupConfig at 22:30 recurring
regards
Motiar
When am scheduling a kron to copy the running-config to a tftp server for every 5 min. Fort first time running config file got saved in TFTP server but on next schedule it throws an error "Not allowed to overwrite the existing file" in TFTP server. Running config files are not getting copied plz help.
Switch(config)#kron policy-list Daily-backup
Switch(config-kron)#cli show running-config | redirect tftp://10.0.0.10/configfile
Switch(config-kron)#exit
Switch(config)#kron occurrence Daily-backup in 5 recurring
Switch(config-kron)#policy-list Daily-backup
Please suggest.
Have you looked at using the archive command rather than the kron?
https://www.cisco.com/c/en/us/td/docs/ios/fundamentals/command/reference/cf_book/cf_a1.html
So you would enter archive in the global config
Under that you set the path to use; in your case that is:
tftp://10.0.0.10/
I personally would use a folder setup so each switch would save their configs to a separate folder.  So the command would look more like this:
tftp://10.0.0.10/switch1/configfile
You would also issue:
write memory
The last command would be time-period
So it would look something like this:
archive
path tftp://10.0.0.10/switch1/configfile
write-memory
time-period 1440
The above will save the config every 24 hours (1440 minutes).  If you put the switch name in the path like switch2, switch3, etc. every switch will backup to its own folder.  Also, with archive, it keeps multiple copies.  You can even use the show archive command to see them.  What archive cannot do is is be schedule for a specific time.  If you wanted to backup every 8 hours you can do that by adjusting the time-period.  When it does save the config it adds a timestamp to the name.
If you want to use kron, then your TFTP server will need to allow files to be overwritten.
Hi Lanbrown,
Thank you for your contribution. I have tried, it works!
best regards
Motiar
