Kron with hostname
Emil Naklicki
I have a lot of switches in need to backup. I have Kron working if I set the file name manually. For example, show run | redir tftp://10.5.7.50/folder/switch.txt. My question is, is there a way to automatically insert the hostname into this command. Something along tftp://10.5.7.50/folder/%hostname%.txt ?
here is an example. The $t should add a timestamp to your filename as well...
archive
path tftp://10.5.7.50/folder/$h-$t
write-memory
kron policy-list SHOWRUN
cli write memory
kron occurence SHOWRUN_COPY at 22:00 recurring
policy-list SHOWRUN
8 Replies 8
Georg Pauwen
try:
The '$h-' will be replaced with your hostname...
Hi George,
Unfortunately this is only creating a $h- file name in my tftp server.
sorry about that: Try without the hyphen:
$h
archive
write-memory
cli write memory
policy-list SHOWRUN
Hello George,
So for some reason when I do this with the following, I get file name $h-$t
cli write memory | redir tftp://10.5.7.50/folder/$t-$t
policy-list SHOWRUN
Seems strange that it won't work in this fashion alone.
However,
It works great in the archive and as a bonus I get a file written every time I write memory!
Thanks again for your help. This saved me a ton of time.
--> kron policy-list SHOWRUN
The variable only works in the archive, not in KRON unfortunately...
Well that explains all the confusion. Thanks again.
Thanks for this, it worked for me.
My question is, is it possible to save the configuration using archive to multiple TFTP servers at once (I have 2 tftp servers)?
I tried adding a second tftp path, but then that becomes the main path for saving the config.
Thanks!
