KVM through Cisco Catalyst 2960C-8TC-L
Ofekharel
I have 2 Cisco Catalyst 2960 connected together via optic fiber. I also have 2 Proxime CE100 KVMs. I want to connect each kvm to each switch. Is it possible to do it?
In addition, I can get into the switch settings. I connected my pc to port 1 and write on the browser 10.0.0.1 or my default getway address but it doesn't do something. How can I get into the settings?.
Thank you,
Ofek
you want to connect the extenders to a port on each switch ? What do you want to connect to the other end(s) ?
In order to use your web browser to connect to the switches, you need to assign IP addresses to the Vlan 1 interfaces. Your PC needs an IP address in the same subnet.
I want to connect VGA ports in each side via the kvm to the switch. I tried to connect it to the same switch port in the 2 switches but I can't even see led on the ports.
