Set up port mirroring on 4500 switch
mramj499
I'm trying to set up port mirroring on a 4500 switch VSS pair.
This diagram is how it's physically set up.  I put in
conf t
vlan 1234
remote-span
exit
no monitor session all
monitor session 1 source int te1/1/10 tx
monitor session 1 source int te1/1/10 rx
monitor session 1 filter vlan 77
monitor session 1 destination remote vlan 1234
end
Then on the 3048, I tried
conf t
vlan 1234
remote-span
The remote-span isn't recognized.  I can't connect my Wireshark workstation directly to the 4500 due to no free ports.  So I looked up the RSPAN articles to direct the port mirroring on te1/1/10 on the 4500 to the workstation.  But since RSPAN command isn't recognized on the 3048, not sure where to go from here.
Any help is appreciated.
balaji.bandi
Trying to understand the issue :
on 3048 the command not recognizing? ( you mean Nexus 3048) - then it is ERSPAN
can you post-show version from that device?
BB
mramj499
Correct, command not recognized on 3048:
C3048-R1-2(config)# vlan 1234
C3048-R1-2(config-vlan)# remote-span
% Invalid command at '^' marker.
HQN-C3048-R1-2(config-vlan)# ?
media Media type of the VLAN
name Ascii name of the VLAN
no Negate a command or set its defaults
shutdown Shutdown VLAN switching
state Operational state of the VLAN
end Go to exec mode
exit Exit from command interpreter
pop Pop mode from stack or restore from name
push Push current mode to stack or save it under name
where Shows the cli context you are in
Show ver:
Software
BIOS: version 4.0.0
NXOS: version 7.0(3)I4(8a)
BIOS compile time: 12/05/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.8a.bin
NXOS compile time: 7/5/2018 11:00:00 [07/05/2018 15:57:12]
Hardware
cisco Nexus 3048 Chassis
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3903336 kB of memory.
Processor Board ID FOC20223XL0
Device name: HQN-C3048-R1-2
bootflash: 1880320 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 560 day(s), 14 hour(s), 16 minute(s), 53 second(s)
Last reset at 951983 usecs after Wed Feb 13 22:58:10 2019
Reason: Disruptive upgrade
System version: 6.0(2)U6(8)
Service:
balaji.bandi
