L2 encryption
nika.katsitadze
Frequent Visitor
Frequent Visitor
Hello
I have 2 sites connected with dark fiber. and i want to encrypt data between this sites. which switch will encrypt data ?
You are looking for MacSec, which is supported on a couple of the newer switches as the 3750-X:
http://www.cisco.com/en/US/partner/solutions/collateral/ns170/ns896/ns1051/product_bulletin_c25-712066.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Sandeep Choudhary
HI Nika,
If yor are saying L2 Encryption then :
The feature you're looking for is called MACSec http://www.cisco.com/en/US/docs/switches/lan/trustsec/configuration/guide/config.html
Devices that support MACSec are 3560-X , 3750-X, 4500, 6500 and Nexus 7000.(Better to consult with cisco)
It seems it's not supported on plain 3560 and 3750.
My suggestion:
Frankly speaking, if you have 2 ASAs you would simply run a site-to-site VPN between the 2 sites and use IPSEC to encrypt the traffic.
Please rate if it helps.
That will probably not the best solution. You need the expensive high-end-models to transmit the data with gigabit or more, and you lose flexibility as it will always be a routed solution with ASA-VPNs.
Hi Karsten,
Thanks for answer.
i told this solution because not many switches support the MACSec even still not clear that which swithes support or which not, so best option to use is site to site vpn connection between 2 remote office with ASAs and you can encrypt the traffice with IPSEC.
