L2 Vlan on 6500 Switch
nitsg.gupta
I have two 6500 switches as core and running hsrp. i need to create one L2 VLAN and don't want inter-communication with other Vlans. i also need running HSRP.
how i can get it. because if create one Vlan and don't create it's SVI interface it is what i neen but for HSRP feature when i create SVI it starts communication with other VLans.
i also dont want to create access-list to dis-allow inter valn communication.
if there is any solution please help me.
thanks,
leekleybm
Place the SVI's in a VRF away from your global routing table.
thanks for replying
plz explain it in more detail.....
If you don't want to use acl's and you have to have a L3 interface for this new vlan then you can use vrf-lite to separate this vlan from your other vlans. Basically vrf-lite will allow you to have 2 separate routing tables, one for the new vlan and one for the rest.
See this attached link for configuring vrf-lite -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/vrf.html
Note the link is for a 4500 config but vrf-lite works on the 6500 as well.
Jon
Thanks Jon,
it was very helpful document but somewhere i think it is related to VPNs and ISP.
at my end how can implement this.
plz help with example for SVIs or VLANs.
