L2TPv3 as backup connection
Marko Krenker
Hi guys,
Is a L2TPv3 through WAN right way to setup redundant connecion between 2 locations of datacenter ?
Primary connecion is ethernet vlan trunk. All vlans are present on both locations.
Regards, Marko
5 Replies 5
Jon Marshall
marko_krenker wrote:
Hi guys,
Regards, Marko
Marko
What is the secondary connection ? L2TPv3 is used when you need to extend a L2 vlan over a L3 routed network but your primary link is an ethernet trunk anyway.
Jon
Hi Jon,
There is no secondary connecion at the moment, but i need a backup connection if primary fails.
I am planing to establish it with L2TPv3 through routed WAN, because both locations have internet conectivity with 7200s, but i'm not sure if this will work properly.
Can you advise ?
Thanks, Marko
Hi Jon,
Can you advise ?
Thanks, Marko
Marko
It can be done with L2TPv3 although not sure why you have a routed WAN and a L2 trunk between the same sites ?
Jon
Hello Marko,
to make the L2TPv3 pseudowire the backup link you need to manipulate STP parameters on LAN switches that connect to the WAN routers, so that the link becomes STP blocked on one side for all vlans of interest.
for example you can increase STP cost with
spanning-tree cost 3000
in interface configuration mode on LAN switches
Be aware that the amount of L2 traffic can be too much for your routers so you should use it only for specific vlans, the few Vlans that you are extending between the two data centers
Hope to help
Giuseppe
Hello giuslar !
Thank you for fast response.
Yes, I know that there can be too much of L2 traffic, and this concerns me most, because routers are not dedicated to this tunnel.
I'll just have to make some tests.
What about packet fragmentation ? Should I set the MTU ?
Regard, Marko
