L2TPv3 on 3640
Hi gurus,
What ios version i can use for my 3640 to simulate L2TPv3.
THanks.
jeff
5 Replies 5
Giuseppe Larosa
Hello Jeff,
you can use feature navigator for this
www.cisco.com/go/fn
I tried looking for plaftfrom C3640 there is only L2TPv2.
if I look for L2TPv3 I cannot find C36540 among the supporting platforms.
However, I've seen one C3640 used in this way at last course I took part.
I think that if you load a late 12.3T you should be fine or 12.4
Hope to help
Giuseppe
Helo Giuseppe,
Yes i did use the navigator and found no match for this. If you notice i think this is inline with my threads, i will try this first and check EoMPLS. Have you tried this l2tpv3?
Thanks for all the help.
Jeff
pseudowire-class NETPRO
encapsulation l2tpv3
ip local interface FastEthernet0/1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
no cdp enable
xconnect 1.1.1.1 1 pw-class NETPRO
Router#sh ver | i IOS
Cisco IOS Software, 3600 Software (C3640-IK9S-M), Version 12.4(17), RELEASE SOFTWARE (fc1)
Router#
Hi Guys,
Still, i dont have any luck upgrading my 3640 with l2tpv3, what should be included on the ios?
#sh ver | i IOS
Cisco IOS Software, 3600 Software (C3640-I-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Thanks.
You have IP Feature set while I had IP Plus
