L3 Redundancy
TroyBolton
Hi, I’ve been tasked with setting up a L3 link between 2 switches and I need some help with my run book to see where I am and what’s missing.
2 Accepted Solutions
balaji.bandi
As per the diagram you need to have trunk configuration between SW1 to SPN1  and allow the VLAN required to streched between them
same canse SW2 and SPN2.
I do not see any connectivity between B1 and B2, you need to have same trunk configuraiton between B1 and B2 and extended the VLAN.
you can create a Layer3 SVI on those switches to enable Layer 3 connectivity - this is just for connection.
you need to sort the routing what you looking to do. (the diagram does not show the goal and routing part)
BB
M02@rt37
Hello @TroyBolton
On your SPn2, you need to create 2 sub interfaces on eth0/0 (one for VLAN 288 and one for VLAN 289), bind each to its respective VRF (office1vrf and office2vrf), and assign the correct IP addresses from the /28 and /29 subnets, while keeping the main interface eth0/0 without an IP and in trunk mode !
Then either configure static routes (per VRF) pointing back to the B1 SVIs or enable a routing protocol within each VRF for reachability... this way SW2 simply carries VLAN 288/289 up to SPN2, where routing and vrf separation takes place !
Hope that clear enough.
Best regards
7 Replies 7
Can you elaborate more
MHM
Hi, sorry i forgot to say that the L3 link i'm setting up is between SW2 and SPN2, and what i need to configure on each of the switches are in the boxes to the right, is there anything specific you'd like to know?
Sorry maybe other help you
I dont get your request correctly.
Sorry again
MHM
balaji.bandi
BB
M02@rt37
Hello @TroyBolton
Best regards
Hi thanks for this can you type this out in a config format me as what you have said is a lot!
If you can simplify your network I can help you
You use BLOCK I dont know what is it' is it SW or host ??
MHM
