L3 Routing Along with vPC Peer Link
Carl Williams
Hi All
I have an environment where i have two nexus 7010 switches, along with 2 nexus 5510's. I need to run OSPF as a layer 3 routing protocol between the vpc peer links.  I have 1 link being used as a keep alive link, and 3 other links being used as a VpC link.
Can someone help me and let me know what the best practice should be for implementing a layer 3 vPC link.
1) Is it best to configure a separate Vpc VLAN i.e 1010
2) Is it best to configure a vrf context keep-alive
3) just have the management address as the peer ip's.
Reza Sharifi
Please have a look at this doc on deploying L-3 routing using a separate connection:
http://bradhedlund.com/2010/12/16/routing-over-nexus-7000-vpc-peer-link-yes-and-no/
Hi Reza
Thanks for the help very useful documentation, please can help me, I know that i don't need to use spanning tree across my VPC enabled links thats understood.
But could you help me in uderstanding which stp protocol is recommended i.e. I know STP mst is more scalable than RSTP routing protocol.
My Nexus Switches will need to become the route of stp and the 5510's in my topology should always see the 7010 nexus platform switches as the route. all ports should end up forwarding advise on this would be helpful.
