L3 switch
dear all ..
i have three network ... i want to conect the three network to L3 switch cisco .. and communicate the three network together ... what it is the right  configuration i must do to do that ???
network 1     :-  10.10.10.0/28
network 2    :-   10.20.20.0/28
network 3    :-    10.30.30.0/28
regards ...
cadetalain wrote:
Hi Jon,
the switch is acting like a router as there are only L3 ports so there 3 conected subnets and no need for routing protocol or static routes on the switch.
Am I completely wrong? I'm gonna try it on a 3550 this evening.
Regards.
Alain.
Alain
If you had 3 other switches and you connected them to your routed ports, one for each vlan then i can see how it would work. But if you need to connect the clients to the same switch how do you then tell them which vlan they are in ? It's not to do with routes, it's to do with how clients on the same switch could use the routed ports as their gateways because there is now no L2 connectivity from the client to it's default-gateway.
Let me know how you get on though, as i have been wrong many times before
Jon
21 Replies 21
Jon Marshall
tariqemad wrote:
dear all ..
regards ...
1) create vlans in vlan database ie.
vlan 10 name v10
vlan 11 name v11
vlan 12 name v12
2) create L3 interfaces for vlans -
int vlan 10
ip address 10.10.10.1 255.255.255.240
int vlan 11
ip address 10.20.20.1 255.255.255.240
int vlan 12
ip address 10.30.30.1 255.255.255.240
3) allocate switchports in to the correct vlans eg.
int gi0/1
switchport mode access
switchport access vlan 10
so a PC connected to int g0/1 would have an address from the 10.10.10.x range and it's default-gateway would be 10.10.10.1
4) depending on the switch you may need to enable ip routing ie.
switch(conf t)# ip routing
Jon
ok thank you very much jon ...
you mean when i use
the routing add dynamic ???? ... and if i have network 4  conect after network 3 i must add the ip route for the network 4 static in the switch ??
regards
you mean when i use
regards
You don't need to add any routes because the switch will see the networks as directly connected. Just give it a go and you'll see what i mean.
Jon
ok .. thank you so much for u'r help
cadet alain
You have 2 options: leave ports as L2 ports and use SVIs to to routing between the subnets(VLANs) or put the ports as L3 ports
Let's suppose option 1:
network 1     :-  10.10.10.0/28  VLAN 10
network 2    :-   10.20.20.0/28  VLAN 20
network 3    :-    10.30.30.0/28  VLAN 30
ip routing
int f0/0
int f0/1
switchport access vlan 20
int f0/2
switchport access vlan 30
int vlan 10
ip address 10.10.10.14 255.255.255.240
int vlan 20
ip address 10.20.20.14 255.255.255.240
int vlan 30
ip address 10.30.30.14 255.255.255.240
second option:
ip routing
int f0/0
no switchport
int f0/1
no switchport
int f0/2
no switchport
on each host as a default gateway put ip address of the int Vlan corresponding to the subnet
Regards.
Alain.
Alain
I can't see how your second option would work. How do you then connect a client to the switch, and what vlan would it be in ?
Jon
yeah i think also that !!! how can do that ?? please Alain if you can explain more about the second choice
Hi Jon,
Regards.
Alain.
cadetalain wrote:
Hi Jon,
Regards.
Alain.
Alain
Jon
dear ..
my plan is to connect three router ( three network )  to the L3 switch .. then from each router connect to another router ... so now i can do that by the Alain configuration ???
tariq
regards
tariqemad wrote:
dear ..
tariq
regards
I think Alain and I read the question a bit differently.
My answer was based on the idea that the clients would also be connecting to the same switch. However if you simply want to use the L3 switch to route between networks but no clients will be connected to the switch then Alain's second option would indeed work.
Jon
ok thank you
Hi Jon,
I just tried with 2 laptops directly connected on 2 routed ports in 2 different subnets on a 3550 and it works.
Regards.
Alain.
cadetalain wrote:
Hi Jon,
Regards.
Alain.
Alain
I think we both read the question differently. The test you did will indeed work. What i was saying if you took one of those laptops (or both) and connected them into other (non-routed) ports on the 3550 how do you then assign them the routed ports IP addresses as default-gateways ?
This is where i think we answered different questions ie. you were talking about making the switch a router and any clients were either connected directly to the routed ports or were connected to other switches which then connected to the routed ports. I agree that this would work.
What i was talking about was having all the clients connected to the same switch as the routed ports are on. If you did this you couldn't assign a client into a vlan and then use a routed port on the same switch as it's default-gateway.
Am i making sense ?
Jon
