Lab - Basic Switch Configuration
jgipsonrandle
Community Member
Hi, im cisco student right now im in need of help with the Lab- basic switch configuration. I'm trying to figure out  part 2 and how to use the enable command to enter EXEC mode in packet tracer.
 You can share the lab and the lab requirements. But, you can use the command "enable password 'password'" or 'enable secret 'password'
You need to be in privilege mode
switch#
Switch>
Switch>
Switch>en
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#ena
Switch(config)#enable se
Switch(config)#enable secret ?
0 Specifies an UNENCRYPTED password will follow
5 Specifies an ENCRYPTED secret will follow
LINE The UNENCRYPTED (cleartext) 'enable' secret
level Set exec level password
Switch(config)#enable secret test
Switch(config)#
switch#
Switch>
Switch>
Switch>en
Switch#conf t
Switch(config)#ena
Switch(config)#
this worked a little but when i got around to switch(config)#ena, it started to say incomplete command.
switch(config)#enable password test
You need to type the whole command. You can also use tab to complete but as you are leaning, type the complete command.
 Use exclamation Mark if you are not sure.
