Lab simulation in VIRL
sandevsingh
Hi folks, I am using Cisco VIRL to build a lab environment. My issue is when I click on "Simulation", it opens a new tab with the same name as my lab design, but appends some random characters after it. Example - if my design is mylab1.virl, the simulation created is "mylab1_xUdF7g". Now note here the different names.
Even though i save my simulation and select "overwirite" the existing files, I tend to loose all my config when I close my simulation and run it again. Why is this happening? Any suggestions?
Harold Ritter
To save the configuration for the VIRL simulation, you need to right click on the tab (in you case mylab1_xUdF7g) and use the "Extract configuration(s)" option.
